Julies_Nguyen
Jun 7, 2026 3:25 AM UTC
Reset Slot Button
I wish there were a "Reset Slot" button next to the slot that has a "Modified" tag. This could help me a lot to reduce the steps to reset the slot. I guess while building this feature, the dev team might have guessed this action is not welcome for the slot. But in some scenarios, for example, I want to reset the slot whenever I accidentally change something in the slot, which causes the slot to freeze and not receive new updates.
adamsmasher
Jun 7, 2026 10:12 PM UTC
Hey, ​@Julies_Nguyen! Thanks for the suggestion - I can definitely understand why you’re looking for this as a feature!
Are you looking for this as an option specifically in the properties panel (where your screenshot shows), or just the feature in general? It is possible to reset one with options the “More actions”. See the Reset a slot section in the Use slots article for instructions. Even though you can access it there, I can see a reason for including this in the properties panel, too.
Julies_Nguyen
Jun 9, 2026 7:32 AM UTC
Hi, thanks for the reply. I'm already aware of the Reset option inside the Slot’s properties panel. However, this workflow isn't very convenient when I need to reset slots frequently. I would prefer to have the reset button displayed directly on the Component’s properties panel (which hosts the Slot) for quicker access.
Oh, btw, I also think the 'Modified' tag on the slot should be highlighted a bit more. This would help me quickly notice which components have custom slot changes
Kerry_Johnson
Jul 9, 2026 12:00 AM UTC
This would be a nice addition, but I really hope Figma pulls through and doesn’t drop the link at the slightest change like it currently does, then we wouldn’t have to reach for this kind of action as often.  I think most of us wouldn’t mind waiting a bit to be able to receive upstream component updates through the slots if that’s the concern and reason why it unlinks in the first place.
