harsha20599
Feb 17, 2021 10:33 AM UTC
Replace a layer with component
We recently migrated into Figma and imported all our sketch files. I created a solid DS in Figma. Now the problem is, while working on old files, It’s hard to remove a layer and place the component at the same place.
It’s been so much annoying and it’s a life saving feature to have something like replace layer with component.
Do you also faced same problem ? Please help me out if you have a workaround or plugin that eases this.
Dominic
Mar 21, 2023 4:44 PM UTC
Using Select Layers plugin is cleaner… not promoting it, just is and it’s free:
  1. Copy your component
  2. Select all (cmd/ctrl + A)
  3. Run plugin called Select Layers - Select Layers by Name, exact match checked (or select any relevant category)
  4. Step2 selects all relevant layers, then simply cmd/ctrl + shift + R to replace all those layers.
Note: sizing and location have to be identical for replacement to be clean. Set your object/component how you want it before Step 1, then copy it.
