Carey_Spies1
Jun 23, 2023 9:34 PM UTC
Reorder variable collections list
Can anyone figure out how to reorder the list of variable collection in the fill dropdown? The layer ‘mode’ assignment appears to sort correctly alphabetically, but the pick list under the fill menu does not, which is a huge painpoint, and will definitely lead to my designers picking the first color they see instead of the semantic one.
Correctly sorted - numerical
Screenshot 2023-06-23 at 2.28.47 PM
Incorrectly sorted - 2. is at the top instead of 1.
Dmytryi_Berezovskyi
May 29, 2024 10:37 AM UTC
It’s been a year but the problem is still the same. Has anyone found a solution yet?
Product_Indaboski
Jun 3, 2024 11:00 AM UTC
it’s 2024 🥴
Janne_Lehtinen
Jun 19, 2024 10:34 AM UTC
Variable collections are ordered alphanumerically, but you need to restart Figma in order to see the change.
Margaret_Shear
Jun 23, 2024 2:47 PM UTC
I found a sneaky solution to this!!!
  1. Update the name of the Collection you would like to appear first in the list and prepend it with a space
  2. When you save it, it will show up at the top of the list—and the spaces won’t show in the Collection name except when editing! 😍
  3. If you want to curate the order of the full list of Collections, you can use descending amounts of spaces to control the order—the items with the most spaces will show up first
For example, if you have 8 items you would like to curate the order of, add 8 spaces to beginning of the first, 7 spaces to the beginning of the second, and so on.
If you want to get fancy you can add dividers by creating empty collections using em dashes to show up as dividers, ordered using the same scheme as above.
Armin_Rouhanian
Jun 23, 2024 3:36 PM UTC
Figma needs to bring back the “Little big updates” campaign again. However, I think we can wait a little longer and see what Config2024 brings. I’m looking forward to seeing them add this feature.
Armin The Riverman
Agni_Kaster
Jun 25, 2024 2:53 PM UTC
… … … OMG 🤯
Li_Ziwei
Jul 3, 2024 2:45 AM UTC
Unfortunately, this does not change the list of variable collections in the fill dropdown
Vicky_Tran
Jul 4, 2024 6:00 AM UTC
I tried. it’s ok. You just reload. The order will be updated
wllung
Jul 14, 2024 7:02 AM UTC
wow. i can’t believe this is an issue. Please label variables as beta until it has minimum features.
edited: reloaded the page because the color swatch menu was getting stuck to mouse movement on selection (modal doesn’t go away, instead it just follows the mouse around) when the file reloaded, variable collections are now in a weird order. it’s not following the order it was created, or alphabetical, it’s just completely random. this is insane.
Jul 16, 2024 2:14 PM UTC
This needs really needs to be fixed… Same as last reply; Collection order is not following any logic. Suuuuper annoying.
