Sarina_Katznelson
Feb 25, 2021 8:29 PM UTC
REM and "font-size" for Inspect
Our developers spend a lot of time in Figma Inspect, having to convert everything from pixels to REM. Implementing a way to specify the document’s “font-size,” or the equivalent of 1 REM and being able to turn on REM measurements in inspect would save so much time and make our design to development handoff easier.
edit: Yes, we could use Zeplin but we are an enterprise team with many projects - why pay for yet another subscription if Figma could implement this one thing?
Gareth
Feb 26, 2021 11:25 AM UTC
Use Zeplin 🙂
Sarina_Katznelson
Feb 26, 2021 6:14 PM UTC
Please see my edit 🙂
Caroline1
Mar 4, 2021 7:13 AM UTC
YES - I’m surprised this doesn’t have more votes!! Thanks for sharing @Sarina_Katznelson
Marianne_Carmona
May 24, 2021 7:36 PM UTC
Does anyone know of a plugin? This is kind of a show stopper for me. The manual process of converting px to rem is error prone and very time consuming.
Does Sketch do this?
_Hal
May 25, 2021 2:23 AM UTC
Maybe this one?
Figma
Mariana_Caldas
Jun 5, 2021 12:30 AM UTC
I’d love to see that on Figma too.
Andreas_Bossard
Jun 25, 2021 2:56 PM UTC
Yes, this recalculating from px to rem takes unnecessary time.
Two potential workarounds:
  1. Devs can install Figma-Plugin Hand››over which does the conversion
  2. There is an npm-package sass-rem which allows you to write px value and the package will then output rem
Karl_Koch
Jul 8, 2021 8:30 PM UTC
Thanks for the shoutout on my plugin Hand››over 😊! I built this for this exact issue, to help my dev team out!
Ania
Sep 10, 2021 2:53 PM UTC
Hi Karl, I’m trying to use your handover plugin, however, it doesn’t seem to work for me (desktop app). What is the expected behaviour? Do I need to enter all numbers in order to get the conversion? When I enter only some of the numbers nothing happens after clicking “Convert” 🤨 Reset button works fine. any advice?
Karl_Koch
Sep 15, 2021 6:01 PM UTC
Hey Ania! So the way it works is to only update the values that are present in the current top-most selection (although you can override these by typing in any input field on the plugin if you wish). So if you select a parent frame, only the values for that frame will convert. If you want to see values for a specific child, you need to ensure only that child is highlighted. This is deliberate as it helps avoid confusion in a frame with many elements that could contradict each other.
I’ll be shipping an update that converts on selection change so you don’t need to press any buttons but those values should update automatically.
Edit: I shipped this update.
Let me know if you’re still having issues!
