Bryan_Berger
May 19, 2021 4:06 PM UTC
Reference a branch in another library
First and foremost, branching is a great addition to Figma, thank you!
Here is some background on how our Style and Component libraries are setup:
Project: Design System
File 1: Styles (text/color/other token styles)
File 2: Components (primitive components, larger organisms, and some templates)
What I’d like to do is create a branch in File 1 and change our brand color and add some text styles.
I’d then like to “stage” this branch so that I can reference it in File 2 (another file) and test some of the changes downstream in components to see how they might look before merging and publishing File 1 (in case there are things I need to change/add).
I would love some suggestions on how I might accomplish a workflow like this, or if it’s something that might be supported in the future.
Thanks!
Amy_Martens
Jul 3, 2024 10:17 AM UTC
This would be a major improvement to the entire workflow for design systems. I should be able to access the components of a branched library to test changes against the consumer files.
Is this any closer to being considered in a future update? The organisation plan really needs the advanced features to be more joined up. Currently most of the advanced features are only half as useful as they should be
Patrick-Plaggenborg
Jul 15, 2024 9:40 AM UTC
Just upgraded to able to use Branches and this is an important feature we’re also looking for.
When your organization grows and you have a Design System Figma Library file containing your components and are using separate Figma files for Layout designs you inevitably run into this problem.
For a new layout in File A you might need to use an updated version of a new component in your Library file B.
Right now it is possible to simply copy/paste the new/updated component from the Library branch and use it in any other file. The cool thing is that it actually keeps the reference to the component.
The problem is that wherever you use an instance of that new component it will keep notifying you of a necessary component update to be done to keep it in sync with the Library Main file.
It’s very difficult to make sure to not accidentally click update for that component or to apply ‘All updates’ in a file.
Would be nice if any copy/pasted component from a branch would keep its reference to the version in that specific branch unless overridden to fall back to its Main File version.
EllisC
Oct 18, 2024 11:10 AM UTC
Any updates on this, Figma? How can design teams effectively support a business with systematic approaches if we can’t visualize large-scale design changes, like rebrands, through the design system?
Developers have had branching, staging areas, and similar tools for years, but design is still lagging behind. To close this gap, we need features like these to showcase the true power of design systems, enabling smoother collaboration from designers to development.
Can we get some meaningful upgrades to the tool instead of these monthly gimmick updates? We need features that actually make us more efficient. This is just one example of many that would genuinely elevate the design and creative process across the industry.
Corey_O_Brien1
Nov 13, 2024 10:43 PM UTC
Bumping this topic up to the DS Project team
Preslava_Petrova1
Dec 18, 2024 10:55 AM UTC
A bit late response to that but since I have issues with branches for the 47854th time I decided to look up the forum. My way of dealing with the fact that my Design System is in a separate file and I can’t use branch variants in another branch is stupid but it works most of the time.
I started making branches of the DS with an empty page called “Screens”. I would copy/paste designs on this page that will use the new components. Then I would color code them - new screens that need to be transferred are in a brighter color and old screens that will get updated just from publishing the library are just white. When merging the branch I’ll move them to the correct project file.
The pain begins when I’m working on V2 of something while the dev team is still on V1 or BETA and I can’t merge the older versions I need. As far as I can see most people here have this issue and I kinda regret that I went with that decision for branching… It has created more issues than goods and it’s already too late to go back without useless labor.
Aurelien_Sesmat
Jul 3, 2025 8:48 AM UTC
A little UP for this topic to keep it warm!
I have this need and it would be cool to implement this feature in the future :)
