Charles_Lai
Jun 3, 2021 4:24 PM UTC
Prototype: disable navigating screens through keyboard (left/right buttons)
When using a Figma prototype, there should be a way to disable the ability to navigate through screens via left & right keyboard buttons. Some research participants are inadvertently skipping through the prototype this way, rather than clicking hotspots.
Is anyone using a plugin or workaround to help solve this?
Averyy
Feb 9, 2023 8:36 PM UTC
@tank666 The problem is that it isn’t enforced if you share the link from the app.
Josh.C
Feb 20, 2023 11:47 PM UTC
@Figma_Support would this be considered as a bug, given that the desktop app isn’t adding the ‘&disable-default-keyboard-nav=1’ to the url string when creating the prototype share link?
May 12, 2023 4:58 PM UTC
Hey @Figma_Support is there anybody looking into this? This seems like a major bug. You should be able to share a prototype w/settings that you decide.
Jason1
Sep 7, 2023 9:24 PM UTC
bump.
I am doing a lot of keyboard-driven prototypes, and requiring them to be published via web so that my testers don’t need to modify the prototype settings themselves is an inconvenience at best, and embarrassing as a default if/when I forget.
Dec 9, 2023 3:32 AM UTC
I wonder why this has not been fixed yet? It’s nuts
Dec 19, 2023 2:31 PM UTC
Hi, still the prototype setting is not set when prototype is shared or uploaded in a usability test application. Especially the most important one is disabling the keyboard navigation . Please fix this.
Jan 5, 2024 8:52 AM UTC
I’m not sure if it is what you’re looking for, but I faced the problem that all my screens of mobile app are simply from one to another by tapping on the sides (same as by arrow keys) and this option “Disable keyboard navigation” is not the solution cause you still able to see all the screens.
I was messing around with the some options and I FOUND THE SOLUTION. You need to create Flow! Select the first screen, on the panel click + on the Flow starting point and voila!
I think the main logic of the Figma is to navigate through the screens in Prototyping just to be able quickly inspect some stuff without hopping back to Design file, but if you want to have strict direction from one screen to another as you see it by your site map, you need create Flow, that disable this navigation feature.
Jan 17, 2024 5:56 PM UTC
I had this issue and fixed it.
Make sure your first screen in the prototype uses a Flow starting point.
Happy prototyping!
