Harald_Skogland
Aug 31, 2023 8:05 AM UTC
Preview window
The new preview window in Figma client is great!
It would be nice if this could be moved freely outside the window size of the Figma client. This way it would not obstruct the Figma UI and can be moved to a secondary display.
piotrek
Aug 31, 2023 8:21 AM UTC
+1, it would be awesome
Oleh_Shydlovskyi
Aug 31, 2023 8:50 AM UTC
You can just open second Figma Window using shortcut Command + Shift + N, and drag full prototype view to the second display.
Harald_Skogland
Aug 31, 2023 10:01 AM UTC
It’s a relevant suggestion but, the Preview window and Present window have different purposes. I want to be able to use the Preview window in a better way, while working on building components. I don’t want to concern myself with creating interaction flows necessarily at that point in my workflow.
Oleh_Shydlovskyi
Aug 31, 2023 1:33 PM UTC
You can open Preview as well in new window, it behaves like you launched second copy of Figma app
Harald_Skogland
Aug 31, 2023 3:16 PM UTC
Yes, I’m aware opening a second window of Figma client will also be able to display the preview window. But that won’t accommodate the workflow and feature that I’m looking for. The preview in my first window of Figma will update display by the frame I have selected in currently open file. The preview in the second window will not change it’s display by interacting in the first window, only by selecting a frame in the second window. As is expected. What I would like to see, is a preview window that updates by frame selected in my file and that this preview window can be displayed outside the bounds of my Figma window.
Oleh_Shydlovskyi
Aug 31, 2023 3:21 PM UTC
Ah, makes sense, yep
piotrek
Aug 31, 2023 6:08 PM UTC
Exactly, escecially that on Config they talked about this feature as a quicker way of preview prototypes which should helps you to get preview more often.
May_2022_Calendar
Sep 5, 2023 3:34 PM UTC
Loving the new preview feature in Figma! Being able to quickly see your designs in an actual browser window is super handy.
Great call on suggesting the preview be movable/resizable outside the main Figma window. I’m often working with Figma on one display and have my preview on a second screen. Having to keep the preview contained within the app makes it block too much interface.
Being able to freely move and resize the preview window like a standard browser would make multimonitor workflows much smoother. You could throw the preview on a separate display and focus just on the Figma UI on your main screen.
This seems like a simple tweak that would really improve the preview experience. Hope the Figma team considers allowing that kind of flexibility and control over the preview window placement/size. Keep up the great work!
May_2022_Calendar
Sep 5, 2023 3:55 PM UTC
I love Figma
May_2022_Calendar
Sep 5, 2023 3:56 PM UTC
I created 2024 calendar on Figma,it looks perfect !!! Thanks Figma.
