Daniil2
Jun 9, 2021 2:07 PM UTC
Plugin for viewers
Hello!
I ran into a problem that I could not find in your help. There is a Status Annotation plugin, it is very well for work’s control. I make a design for a client, and he’s could control the process with this plugin. But he’s a manager, not a designer. The client usually acts as a viewer, not an editor. This is done so that he cannot spoil anything in the design. But the viewers doesn’t have access to the plugin. Plugins can only be used by editors.
Could you make plugins available for viewers? It will be so usefull.
Thanks
AZo
Jan 20, 2023 9:12 PM UTC
yes! just let us choose to make it open to viewers or not - problem solved!
Alexandra_Kandler1
Jan 31, 2023 8:45 AM UTC
Yes, please! We’d love to make use of a localization plugin. It’d be easiest if the devs can push the strings themselves directly from Figma, so it’s one workflow for one person and not multiple flows for multiple people.
Mar 2, 2023 7:45 AM UTC
👍 This would be awesome
Selena_Jiang
Mar 3, 2023 8:44 PM UTC
give it to us
S_e_b_a_s_t_i_a_n
Mar 8, 2023 3:05 PM UTC
We need this, please!
Cynthia7
Apr 13, 2023 3:20 AM UTC
Annotation intentionally for viewers to add notes. Really need this, please!
Apr 21, 2023 6:52 PM UTC
We have a plugin that helps developers convert Figma to code more easily. The developers usually only have view access, so they cannot use the plugin. This is a really big pain point for us.
May 19, 2023 2:18 PM UTC
this would be very useful I want to use a export presets plugin but I am a developer not designer
joel.torner
May 24, 2023 7:02 AM UTC
+1+1+1+1+1+1+1+1+1+1+1 please
danhendersonede
Jun 23, 2023 9:33 PM UTC
Plugins made for DevMode can now be run by viewers!
Plugin in Dev Mode can access the current page, listen to events, and make network requests, but crucially they cannot modify the document, with the exception of writing certain metadata like pluginData and relaunchData. So, any method or operation in the plugin API that creates new nodes, deletes existing nodes, or modifies an existing node isn’t available in Dev Mode.
Read more: Key differences between plugins in Dev Mode and other plugins
