Ash.Sharifi
May 6, 2021 3:46 PM UTC
Override auto layout direction on the instances
Hello Figma!
I can not change the direction of the Autolayout on the instances of a component. I can not understand why such a great feature is disabled on the instances and why not allow us to overwrite it?
There are so many incidents that I would have wished to be able to change the direction of the Autolayout in the instances of the component but right now I have to create multiple variants. 😦
Pinned Reply By djv
Hey All, thank you for your continued feedback!
Right now, you cannot directly override an auto layout direction on a component instance in Figma because the layout direction (horizontal or vertical) is locked to the Main Component. But there are temporary solutions to allow you to change the auto layout direction:
  • Use Component Variants: Create separate horizontal and vertical variants inside your main component, then switch between them using a variant property dropdown in the right sidebar on your instance.
  • Detach the Instance: Right-click the instance and choose Detach instance to break the link, enabling you to freely change the auto layout direction on the resulting frame.
Hope this helps clarify and gives you a couple of new options to try! If there are any promising updates from the team on when or if this can be implemented, we’ll be sure to provide an update.
Nikki3
Dec 4, 2024 12:15 PM UTC
100% add this. This would also mean when content is chosen at the end design point, that changes would carry through if you then changed the layout choice
Rob_Nagel
Dec 17, 2024 10:29 AM UTC
No news about this yet? only focus on pricing or what?
Doug_Scott
Jan 14, 2025 12:12 AM UTC
👍 +1, must have feature. 👍
Shelby_Tessier
Mar 4, 2025 11:23 PM UTC
would love to have this feature please so we don’t need to have multiple different designs for different breakpoints!
nicnac147
Mar 12, 2025 10:07 PM UTC
Hey all,
I too would love this feature, BUT in the meantime I have found some sort of workaround : I work with child elements instead of the parent component.
So if you have FRAME 1 with 3 blocs (frame 2,3 & 4) (left to right) in desktop, you cannot copy FRAME 1 in your mobile view and change the layout. So instead create the components at the second level : FRAME 2,3 & 4 become components, and it is those frames that you copy in your mobile view.
At least you will be able to edit the content itself and have it replicated accross your breakpoints.
George_Konig1
Mar 31, 2025 9:49 AM UTC
Still waiting for this feature in 2025.
Paul_Nattress
Jul 18, 2025 12:02 PM UTC
Would also like to see this feature implemented. I have create variants for this which is cluttering my design system.
Stanislav_Krofta
Jul 30, 2025 1:52 PM UTC
This is absolute MUST! It would enable us to anyone to setup fully responsive designs using variables!! Please!!!
Damian_Summersall
Oct 10, 2025 8:44 AM UTC
Same here, would make our design system so much easier to manage.
Ana_Gancheva
Oct 30, 2025 2:33 PM UTC
It’s crazy that this ticket has been open for 3 years and there has been no movement.
Having auto-layout direction control on a child instance is one of the main reason we continue reattaching components! An override option will have a very positive effect on design consistency and workflow efficiency.
