Nested property hidden with multiple selection
Show first post
calila
  • August 8, 2023
Can we get this fixed?
It shouldn’t be such a big deal and will improve the workflow tremendously.
Henry_Agnew
I ran into this problem today. And I have about 50 nested instances that I’m going to have to change one at a time 😐
Dustin_Hansen2
Just bumping this to keep it active. Feels like a bug? Hope it gets fixed…
Jamal_van_Rooijen
Bumping this as well to keep it active. I really need this functionality. especially for components like tables.
Zohra_Jayaraman1
I’m having the same issue. It’s super annoying because I spent all that time creating nested instances of all my components and now it’s no longer going to save me the time I thought it would when manipulating multiple instances at a time.
@Figma please fix this ASAP!
Zohra_Jayaraman1
Has anyone submitted this as a bug report? I don’t think Figma will read this otherwise.
dvaliao
  • 4625 replies
  • October 9, 2023
Hey All, sorry for the delayed reply!
We shared this thread with the team to review, and the team confirmed that this is not a bug, but rather a current feature limitation.
We’ve updated this thread to a feature request for future consideration, but to be transparent, right now, allowing for this ability would cause major performance issues.
Marijn
  • 11 replies
  • October 23, 2023
+1 Same struggle here!
David_Ridilla
Is anyone aware of any plugins that can provide and relief for this issue? All our content blocks are nested and the point is lost without mass editing.
Adriana_Mandjarova
+1 working with calendar components is really difficult.
dvaliao
  • 4625 replies
  • November 16, 2023
Hey All,
Today we launched Nested component props!
Now nested component properties are visible in both the component playground and in Dev Mode. Previously, only the parent was visible. Learn more about component properties.
Zach_Ward2
While these are helpful for some uses, this doesn’t cover the needs for the original issue/post.
When selecting multiple components from a single component set, you aren’t able to adjust nested component properties. You have to select them individually to change them in the properties panel.
Seems like a no brainer to have this as an option. I’m sure it was decided to avoid it due to some architectural issues?
Papes_Christoph
Hey @dvaliao. I just tested what you mentioned here: When I expose properties from a nested instance in a component, the nested instance properties show up in design mode, Dev Mode component playground, but not regular Dev Mode when the component gets inspected (as you mentioned). Has this feature been removed again?
Papes_Christoph
Hey David, the Selection Variants plugin by @Gleb might help to a certain extend 🙂
Chris64
  • 8 replies
  • January 9, 2024
+1 Having complex table components with 20+ rows. Table design without batch editing is no fun. ;(
have to make shitloads of variants instead of using nesting because of this 😢
Paul_Lyons
  • 14 replies
  • January 17, 2024
Any news on an update to this @figma_support
daken
  • 22 replies
  • February 13, 2024
need this man 😪 😗 😗 😪 😪 😪
dvaliao
  • 4625 replies
  • February 13, 2024
Hey @Papes_Christoph,
It has not been removed. Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so we can take a closer look.
dvaliao
  • 4625 replies
  • February 13, 2024
Hey @daken,
As mentioned above, this was already launched in November 2023.
peter_fiek
I don’t think the solution was accurate to what the OP was asking because I’m having the same issue today. zach_ward2 explained it properly above.
Yes, we are aware that nested properties can be exposed now, but when multiple component layers are selected, the nested properties disappear from the side panel.
frolovv
  • February 14, 2024
Hi! I checked the link and it seems to me that it doesn’t correspond to the question. When I select multiple instances, Figma doesn’t display the properties of the nested instances.
dvaliao
  • 4625 replies
  • February 20, 2024
Hey @frolovv,
The option to expose nested instances is available only if a main component:
  • already has an exposed nested instance, or
  • contains nested instances with component properties applied to it
If you don’t see the Nested instances option, try applying a component property to a nested component first.
More info here:
Figma Learn - Help Center
daken
  • 22 replies
  • February 26, 2024
  • 2322 replies
  • February 27, 2024
Hi there,
Around the 5-second mark in your video, it appears that you’re selecting two instances. Could you try selecting just one instance to see if the properties are shown?
Additionally, please ensure that you’ve exposed the properties of the nested instances in the main component. If you see the properties of the nested instances like in the attached sample, you should be able to see them when you click on the instance individually.
Please feel free to let us know if you hav further questions!
Toku
