TR0608
Aug 12, 2026 2:12 AM UTC
Need aspect‑ratio options added for "Make an image". It should exactly match the aspect ratio according to the resolution set in the prompt.
 "Make an image" can’t generate images in different aspect ratios, like 16:9, 4:3, vertical formats and more. It only outputs 1:1 square images by default.
Even when requesting other ratios, outputs are inaccurate with large deviations, which is really inconvenient.
Freely selectable and correctly matched image ratios are urgently needed for "Make an image".
If there’s any existing workaround to generate images at the desired aspect ratio, please share it. Thanks!
peilun Fu
Oct 20, 2026 7:08 AM UTC
create a gray rectangle that meets your size requirements, focus on it and use “Make an image” XD
anniewarner
Oct 20, 2026 7:25 AM UTC
I agree! Having precise control over aspect ratios like 16:9, 4:3, and 9:16 would make image generation much more useful for different platforms. One workaround is to generate the image first and then crop or resize it using an image editor, but that can cut off important details. Native aspect-ratio controls would be a much better solution.
Hellen charless
