Koen_van_Niekerk
April 29, 2021
Multiple overlays + interact with area outside overlay
  • April 29, 2021
  • 19 replies
  • 17123 views
Maybe the overlay functionality was originally designed to simulate modals.
But two (unnecessary?) limitations limit their power for other applications:
  • The fact that I cannot have more than one overlay open
  • The fact that I cannot interact with the area outside the overlay is very limiting
Please allow for having multiple overlays and for interactions outside of an active overlay. If you need regular modal behavior, you can still have that by checking a checkbox (off by default) in the Figma UI.
Limitations like this mean I have to back & forth between Figma & Protopie. I fully realize that Figma may not be aiming for HiFi prototyping (text fields, conditionals and even sensors). But just a couple of well designed tweaks and features will enable me (and probably others) to do 90% of my prototyping in Figma…
Example:
  • Image you have an image grid with smaller images.
  • Clicking an image will make it go full size.
  • A prototyping execution for this is loading an overlay with the bigger version of the image
  • You can browse the bigger images via “Swap overlay” with buttons on the overlays.
  • You can close the bigger image via “Close overlay” with a close icon on the overlay
Limitations
  • You cannot navigate to a completely different screen if the nav that triggers that screen is not on the active overlay. I have to close the overlay before I can use that nav.
  • You cannot browse the bigger images via “Swap overlay” with buttons that are not on the overlay.
Cian_O_flynn
November 17, 2021
I would also find this suggested feature very necessary.
I often make UI’s that have multiple toggle buttons on the same screen and would love to find an easy solution to have a user toggle on and off as many buttons as their hearts desire and move on to the next screen. Right now I am working on a meal planner that involves the user picking the days of the week they want to have a specific meal. You can toggle on and off all 7 days. Meaning I would have to make 2!7 ( 2x2x2x2x2x2x2) = 128 different combinations screens 😦 ( don’t check my math )
Sophia2
December 5, 2021
I also really need this feature. My use case is a user interface where the user can toggle on/off 5 different buttons. Each button opens a specific overlay that has to stay open, also when other buttons are toggled on.
Katie_Donahoe
March 11, 2022
I would love to see this feature! When building a prototype for a search/filter experience this is so critical.
We need this functionality to build realistic prototypes, not just click-through prototypes.
Madiha_Zaidi
April 8, 2022
Hi All, I agree… it’s the biggest requirement at the moment. Figma please check this out. I am sure, It’s not that complicated to create this feature.
Alex_Williamson
April 20, 2022
Darren_Beason1
Add On Click > Close All Overlays
Darrel
July 22, 2022
Just chiming in to say “yes, please!”. As much as I love Figma, I’m quickly realizing that the prototyping options are severely limited causing a lot of bottlenecks in our workflow.
Sharon12
Yes, please! I’d like to be able to open several overlays at a time and then move to the next screen with those selections open.
Scott8
September 24, 2022
Any update on this? As stated many times, it’s easy to open an overlay, and swap out an overlay, when it’s the same size and in the same position. I need a button in that overlay (Dropdown menu) to launch a new overlay (pane/modal) in a different location and with different dimensions AND close out the original overlay. I can get the new pane/overlay to display, and I can figure out how to manually position it (though it is a bit trial/error/tedious) but I cannot figure out how to close that first overlay (the dropdown menu). It really ruins prototypes for colleagues when you’re trying to show intended functionality. Seems an easy fix and a known problem for at least two years now. Figma, hello? Thank you!
King_Cody_ESI
March 9, 2023
Hello? Figma? Anyone there?
I too have the need to have more than 1 overlay open at a time.
