Nazim_Can_Tunc
Jan 31, 2021 7:11 PM UTC
Multiple Flows Should Have Different Device Frames
It would be great if we could select different device frames for each flow. This would give huge benefits to those who design responsive websites side by side.
mr.D
Nov 15, 2023 12:16 AM UTC
Yep, it would be nice to see this fixed.
Margot_Gabel
Nov 24, 2023 2:46 PM UTC
This idea is from 2021! Still needing it every day.
Using Figma since 2018.
Josiah_Pierce
Nov 29, 2023 8:00 PM UTC
Hi everybody. I haven’t read every comment on this thread but I have found a workaround that I like and have been using for several projects. I still would like devices sizes for each flow… but, try this out!
Figma does let you set prototype devices per “page”. Here’s a screenshot of what I do for each project file now. I set up mobile and desktop pages that contain only those device size prototypes, then I assign the corresponding prototype device for each page. You can setup a master Figma file that you duplicate every time you start a new project if you want. I hope this helps some people!
Joseph_Amato
Dec 14, 2023 7:10 PM UTC
Great input, @Josiah_Pierce. Thanks for the input. We appreciate your input!
Margot_Gabel
Dec 15, 2023 1:36 PM UTC
We design desktop and mobile screen in the same page and use the Custom Size setting to show our prototype (to overcome the fact that Figma can still not handle different devices for different flows…), the problem is that the Prototype option Fit Width is not available for some obscure reason. Therefore we MANUALLY add &scaling=scale-down-width to the URL to have it working and to have a proper link to share with client.
Would it be possible to just display it in the Option dropdown like for the Presentation setting?
Morten_Brix_Falslund
Jan 5, 2024 9:26 AM UTC
We need this! 😭
The_Company_You_Keep
Jan 23, 2024 10:24 PM UTC
A solution we use:
• Custom device frame for desktop (1440 x 900px)
• Insert a rectangle the same hex value as your prototype background
• Size rectangle to your mobile width and the difference between 900px and your mobile height (900 – 736 = 164px)
• Set rectangle to fixed position
• Extend page frames by 164px at bottom so this rectangle can hide there once scrolled to bottom of page
Jan 24, 2024 10:13 PM UTC
+1 New to Figma and loving it but already running into the need for this feature as my team designs for different viewports on the same page. Also seems like the new variables feature supports this concept by allowing you to assign your variable modes (mobile, desktop, etc) to a specific frames on the same page. Would be great to treat the device prototypes the same way.
Feb 4, 2024 1:52 PM UTC
+1 This would be a superb feature!
Mateusz17
Feb 10, 2024 12:29 PM UTC
Still nothing? 😦
