Daniel_Robbins
Feb 5, 2021 12:50 AM UTC
Move a page from one Figma file to another
Pretty simple ask: I want to move a page from one Figma to another. I don’t see a way to do it.
Select All + Cut + Paste is not a good solution as I might have locked objects that don’t come with the copy and there might be properties set on the page (background color, etc.) that I might lose.
Kaliah_Perry
Jul 5, 2024 8:01 PM UTC
+1 Posting in July 2024 and looking for this solution! Getting heavy into design work, and could really use the ability to move entire pages to new or pre-existing design files. It would help a ton with organization and workflow!
The copying of components, prototype flows, comments, etc would be an amazing plus. 🙂
Michael_Tardif
Jul 8, 2024 6:33 PM UTC
Does anyone from Figma read these? I would also like to reorganize pages.
Mark_Ro
Jul 11, 2024 1:33 AM UTC
This actually really easy if you set up your Figma properly like they designed it. Every element should be tied to a frame. If you have all the elements organized to a frame then you simply copy and paste the frames from one file to the next. I
do it everyday for multiple website and print design projects where I want to start a new project from the design I did for another client OR I also do this when I want to share access to select people (like a file for just the client vs a working Figma file for my freelancers).
Here are the steps:
  1. Make sure all your elements are organized into their frames (Figma uses the # symbol in the layers ribbon to signify a frame) like Figma was designed. Think of these as layers in Photoshop. Everything needs to be nicely organized and tied to a frame.
  2. Create a new Figma file by going to the Figma Icon in the top left → File → New Design File. This will open a new tab as a blank Figma File
  3. Go back to the original file and select some or all of the Frames you want to copy. Highlight them via cmmd + click (mac) or ctrl + click (pc). Right click to copy or cmmd + c (mac) or ctrl + c (pc)
  4. Go to the new file. Click anywhere and paste by right clicking to paste or cmmd + p (mac) or ctrl + p (pc)
  5. You have all the elements in the same frames and locations in the new file exactly as the previous
Important to note - You cannot do this for pages. However, it takes 2 additional seconds. Simply create all the pages in the new Figma file like you have in the original file and follow the same steps above by copying and pasting each frame per page you want to duplicate over. If you have everything grouped per frame it will only take you another 2 seconds to do this per page.
Moral of the story - keep your designs organized like Figma (and Adobe) want you to. All design elements should be properly organized in frames then in groups and labeled to make your life easy. This also helps when people need to quickly edit your designs.
I have found this does not copy over the prototype setting nor comments. As seen from previous discussions in this thread. That would be very tricky for the developers to do as it requires complex security settings.
Aug 6, 2024 9:26 PM UTC
+1 My team also will appreciate this functionality.
At the moment struggling to copy/paste prototypes and flows when approved and published to PROD.
Lea.P
Aug 14, 2024 1:23 PM UTC
Yes, please. I need to be able to restructure pages within different files with comments (and prototype links). That would be so helpful.
➕ 1️⃣
Sean_Currey
Aug 20, 2024 7:04 PM UTC
Function “move page” please, so we get everything, I want the comments to travel with it.
Jess_Louwagie
Sep 19, 2024 8:27 PM UTC
+1 for this feature request
Kim_Iversen
Sep 23, 2024 9:31 AM UTC
+1 for this feature request yes! Need it!
Francisco_M_Ferreiro1
Sep 27, 2024 9:13 PM UTC
It’s the second feature I’m searching for (today), that’s being proposed since years ago and still isn’t implemented.
Yet we got floating panels that nobody asked for.
Gabin1
Oct 1, 2024 10:10 AM UTC
Wow crazy it’s been asked since 2021 and still not there
