"mark as completed" via MCP server
Here’s the workflow I would like to enable:
- Designer completes work, and marks “Ready for dev”
- [engineering happens]
- Claude code changes from “ready for dev” to “mark as completed” via the MCP server
When I asked my Cowork to do this, it replied:
I was able to open the file and locate the node, but I can’t mark it as completed through this integration. The Figma plugin API exposes a devStatus property, and it correctly read the current value.
Attempting to set it to COMPLETED returned the error: set node.devStatus is not yet supported.
This means the write path for Dev Mode status isn’t available through the current Figma MCP integration — only reading it is. You’d need to change the status manually in Figma’s Dev Mode panel (the status dropdown next to the layer/frame name).
