NAGA_TARUN
Mar 21, 2021 4:47 PM UTC
List of Fonts in selection (like selection colors)
    When we select a particular template or frame on Figma on the right side it will show all the colours did we used on that frame or template that’s a really good feature, Including that can you people also try to show us what all fonts that we used in that template or frame I felt that could be really great move by Figma if you people show the list of fonts that we used in that frame this going to be a great initiative by FIGMA. I’m really apologetic If that feature already existed in Figma I didn’t know where it was? I explored but I couldn’t find that feature.
  2. Add as much context as possible (screenshots, Figma files, mockups, etc.)
  3. Ask questions to bring the community into the conversation
    (e.g. Does anyone else experience this? Is anyone using a plugin or workaround to help solve this? etc.
Tom_Auger2
Apr 17, 2025 4:39 PM UTC
Yes, this is a much-needed feature. The ability to, for example, make a selection around a number of objects that include some nested text fields, and change the font size, weight, even face would be phenomenal - as others have said the “Selection colors” is a brilliant and indispensable options. Doing so with fonts and maybe even effects could be a great feature. Please consider it.
Tom_Auger2
Apr 17, 2025 4:40 PM UTC
As an alternative - is there a way to have a selection and then perform a command to select ONLY the text fields within that selection? That might satisfy some of the use cases here…
I see a “Select all Text Layers” but that’s weird - it seems to select all text layers within the outermost frame, not within what is currently selected. There doesn’t appear to be a “Select all Text Layers within current Selection”.
emma.s
May 7, 2025 6:34 AM UTC
Yes please!
Aaron_Schapiro
May 30, 2025 5:39 PM UTC
Still need this to happen
Samuel Lu
Jul 14, 2025 4:48 PM UTC
The current plugins are insufficient for selecting an exact typeface/font and then replacing all with a another exact typeface (including styling). Please add Selection Fonts feature.
Daniel Newton
Nov 8, 2025 12:25 PM UTC
WHY does this not exist?
Petr_Krykin
Aug 29, 2026 6:10 PM UTC
You can use Style Hunter to check your selection for colors and fonts (even for text with no style attached)
