Andrew_Croce
Mar 10, 2021 9:18 PM UTC
Links between pages in PDF export
I need to create internal linking PDF exports; a multipage document with a table of contents that provides links to the relevant pages.
If I use the link tool, the links generated in the exported PDF go to the web URL of the linked frames, and does not navigate to the page within the PDF. Using prototype linking does not generate any interactivity in the PDF at all.
It would be useful for either the prototyping tool or link tool to generate interactive internally-linked PDF exports.
Egbeyemi_Ridwan
Feb 6, 2023 10:12 AM UTC
This worked for me. Yes, I had to do the linking all over again but it was quite fast to complete. I especially love that I could still do it within Figma, instead of exporting to Adobe Acrobat as advised by some commenters here.
Jun 5, 2023 4:21 AM UTC
If the prototype link can be exported as an interactive PDF that will be perfect. Then I can finish all the linkage in the main element. Or is there any plugin that can do so? I really need some help.
Sep 17, 2023 8:43 AM UTC
Yes please, add the native interactive linking to the PDF exports. It is a mess to do all the work on Figma and then to not be able to use it. For a planner, I need now to go with indesign or ther payd applications, it’s frustrating.
Dylan9
Dec 21, 2023 9:54 PM UTC
This would save so much time! Shareable/interactive PDFs are still a critical part of my workflow and recreating interactions in inDesign/Acrobat/etc. is very tedious. Please add support for interactions in PDF export!
Cesar4
Feb 7, 2024 5:42 PM UTC
The problem is with vector shapes (an icon for example), if it is a button with text or a simple text the solution is:
1 - select the text (Cmd+K).
2 - type the url in the input that appears
3 - go to text properties and remove the underline to the text box
4 - export PDF
Then the text links will be active to navigate outside the pdf viewer.
Florian_ARGD
Apr 28, 2024 2:45 PM UTC
This conversation started in 2021 and still no solution ? Of course there is Pitchdeck but common… $28 !!!
May 4, 2024 8:31 AM UTC
I recently stumbled on this thread and pitchdeck for exactly the same use-case. And somewhere in the documentation for pitchdeck it says that you can setup links to and from individual elements on any frame and it will preserve those when exporting to pdf. I did give it a brief try and it works! So for everyone above who did not get it to work, do give it a try once more.
May 4, 2024 8:33 AM UTC
This is the link for the documentation page. Refer to the paragraph at the very end of the page.
May 4, 2024 8:35 AM UTC
Yes, the pitchdeck plugin is able to do this
John_Sierra
Aug 19, 2024 5:04 PM UTC
@Figma_Moderation < let’s get this interactive links added to your PDFS! we’ve been asking for this over three years.
