Mikka_Wild
May 28, 2026 8:50 AM UTC
Leaner variable entry
Using shift+click the variable search opens automatically on most fields.
The Gap field in AutoLayout is excluded from this and does not have a variable picker icon but it needs to be selected via dropdown every time.
This is inconsistent and I think it should be also possible to have shift+click open the variable search.
#littlebigupdates
Junko3Solution
May 29, 2026 3:44 AM UTC
Hi ​@Mikka_Wild,
Thank you for the feedback!
I understand you've noticed that Shift + click to open the variable picker is not supported on some fields, which feels inconsistent when trying to apply a number variable.
As you mentioned, Shift + click to open the variable picker is not supported on the following fields at the moment:
  • Font size
  • Gap between
  • Layout guide count
  • Width and height
  • Maximum width and height
As an alternative solution, you might want to try pressing [=] instead. I'm on a Mac and can confirm that Shift + [=] opens the variable picker on fields that support number variables, including the Gap between.
For more details, please check the Help Center article below: Apply variables to designs > Apply a number variable
Thanks!
Junko3Solution
Hi ​@Mikka_Wild,
  • Font size
  • Gap between
  • Width and height
Thanks!
Mikka_Wild
Jun 1, 2026 7:32 AM UTC
Hi ​@Junko3,
that’s a neat trick, thank you! I didn’t know that shortcut yet.
Also well documented, maybe in the future there will be a way to unify the entry methods.
Best regards
Mikka
