Powers
Jan 25, 2021 3:10 PM UTC
LAUNCHED: Wrap elements in Auto Layout to multiple lines
It would be really great if there was an option in an auto layout frame where the frame would wrap the objects to the next line. Like this. Objects would respect the padding set in the Auto layout.
Loom
Ryder_Booth2
Jul 14, 2022 6:53 PM UTC
+1 make the auto layout that much more magical… please!
Mantas_Milkintas
Jul 15, 2022 9:04 PM UTC
Yes please! +1
Jenni_Merrifield
Jul 21, 2022 8:09 PM UTC
omg, yes, please - if I could vote on an idea more than once I would seriously consider adding half my remaining votes to it.
I don’t actually think that the full capabilities of flex box would require too much complexity if some of the options are in the main UI and others are in the advanced menu where you can currently choose between packed/distributed, include/exclude borders, first/last on top stacking order and text baseline.
I’d put the following directly on the properties panel:
  • horizontal and vertical z-wrap options (as others have described above)
  • a field for the number of columns/rows along the horizontal/vertical
When the the horizontal/vertical resize of the container is “fixed”, contained items - which can have any resize option - are automatically wrapped at the specified number of columns/rows,
When the horizontal/vertical resize is set to “fill” and the advanced “Spacing mode” setting is “Packed” the same number is used and all contained items are set to “fill”. If the resize is still fill and spacing mode is changed to “Space between” then column/row count switches to “Auto” and the wrap is based on the width/height of the container frame and the width/height of the contained items. In this latter case, items set to “fill” will always fill up what remains of the width/height of the current row/column, forcing the next item into the following row/column. This does mean that if all items are set to “fill” the result devolves to a single column/row but that’s okay because, if the user wants them to be in multiple columns/rows they just have to switch back to the “Packed” spacing mode.
“justify-content” and “align-content” values are handled by the existing alignment square.
“row-gap” and “column-gap” are handled by showing both the horizontal and vertical “spacing between items” elements
“align-items” is on the advanced panel and only enabled when the horizontal or vertical z-wrap is selected. For the horizontal z-wrap, it uses the same three icons as text does for vertical alignment. For the vertical z-wrap, it uses the same icons as text does for horizontal alignment.
Jul 26, 2022 1:44 AM UTC
Needs to happen @Figma_Support
Kevin35
Jul 27, 2022 3:21 PM UTC
wen integration?
Patrick_Raabe
Jul 29, 2022 1:32 PM UTC
cmon guys, u can do it! 🙂 🙂
Arash
Jul 29, 2022 2:37 PM UTC
+1 please, much needed feature
Brian_Bailey
Aug 1, 2022 1:22 PM UTC
+1 Figma is so feature-rich that I was surprised auto-layout didn’t work like CSS Flexbox / Grid
B116
Aug 2, 2022 2:10 PM UTC
How is this not a thing yet?! Doesn’t everyone run into this problem every time they use auto layout?
mtri
Aug 2, 2022 3:23 PM UTC
+1 this would be great
