Carlos20
May 9, 2025 8:36 AM UTC
[LAUNCHED] Set grid row height to "hug" contents
I was super pumped to start using grids for my layouts until I learned of one fatal flaw that killed my excitement :(  The inability to set a row height to hug is simply a deal-breaker for me.
Also no variables support for gaps? really?
Caleb Heidel
Aug 1, 2025 3:16 PM UTC
Just adding on to this! I need a ‘hug’ setting for row heights! seems like a obvious this and I’m assuming ya’ll are working on it? :D please please please!
Caleb Heidel
Aug 1, 2025 3:33 PM UTC
​@Junko3 do you know if this is being worked on? It looks like Penpot already does this perfectly… :/
Glenn_Robertson1
Aug 1, 2025 6:32 PM UTC
This and the ability to set them to %…  Figma really needs to a streamlined way to set hug - fill size percentages %, min - max and all those things you do in a real web app.
It’s such a pain to hack your way into telling a developer we want this to be 8VW with min width 44px and max width 120px. Or give us a command line so we can set our own CSS on objects.
Anna Willoughby [External]
Aug 7, 2025 7:33 AM UTC
wish they’d stop shoving AI garbage that literally no one wants into the app and spend some time fixing stuff like this instead.
Aug 7, 2025 7:34 AM UTC
yepppppp penpot is honestly what i use for my own personal design work now because figma is just on another planet from what designers actually need.
Pavlo_Kiselov
Aug 13, 2025 10:33 AM UTC
Seems like there a way to create rows and columns that hug content. Here is how you can do it
  1. Create a frame
  2. Hit Shift+A, make it auto layout frame, make sure that sizing is set to HUG both directions
  3. Convert it to grid
  4. Now you have 2x2 grid with auto sized rows and cols
There is no direct way to enable this sizing option within the UI, however if you add a layer inside and then you duplicate it it would add another column with “Hug” sizing enabled
Not quite clear how to add more rows though...
Johnson_Ryan
Aug 13, 2025 2:21 PM UTC
  1. Create a frame
Clever trick! Sadly, additional rows/cols initialize as “Auto”. I guess it’s a sign that it’s possible, but maybe it’s just not fully implemented yet.
Johnson_Ryan
Aug 13, 2025 2:58 PM UTC
fwiw, I’m able to tweak the grid configuration through the plugin API, to apply various layouts that aren’t yet available via the Figma UI.  However, it requires setting configuration options that aren’t yet documented in the plugin API.  This gives me hope that this feature is coming sooner than we expect.
Pavlo_Kiselov
Aug 14, 2025 9:01 AM UTC
  1. Create a frame
Duplicating frames inside the grid would create extra columns and rows with “Hug” sizing inherited. This is the only way I found yet.
Jyoti_Ghadge
Aug 20, 2025 6:24 PM UTC
Without hug content, grids are not of much use.
