Carlos20
May 9, 2025 8:36 AM UTC
[LAUNCHED] Set grid row height to "hug" contents
I was super pumped to start using grids for my layouts until I learned of one fatal flaw that killed my excitement :(Ā  The inability to set a rowĀ height to hug is simply a deal-breaker for me.
Ā
Also no variables support for gaps? really?
Thomas_HELLEGOUARCH_BPCE
May 16, 2025 3:53 PM UTC
Simply do not release features that do not have 'Fill or Hug'. Please.
We need to manage accessibility in our mockups, right! šŸ˜‰
Saquib Feroze
May 16, 2025 5:09 PM UTC
Use Auto Layout Vertically Instead of Row Grids
  • Create a parent frame with vertical auto layout
  • Set each ā€œrowā€ or section to Hug Contents
  • Control spacing with gap or padding
  • Forget Figma's visual row grid entirely
šŸ”ø Bonus: You can still overlay a custom guide system (e.g., horizontal lines) using vector lines or helper frames if you need visual row cues.
šŸ”§ Alternative Trick (Manual Grids with Auto Layout)
  • Use rectangles or lines as faux "grid rows" with labels
  • Nest auto-layout frames inside that respect content height
  • This gives you the visual feel of a grid with the flexibility of hugging content
Elena Darling
May 20, 2025 5:21 PM UTC
AsĀ the grid cannot be set to fill for width and height, it’sĀ not truly responsive. Would love to see an update on this one to match dev grids better!Ā šŸ’ƒ
Elena Darling
May 20, 2025 9:59 PM UTC
Ah I’m incorrect lol, I think the real update I want here is to delete my past forum repliesĀ šŸ˜‚
Alvaro_Navarro1
May 21, 2025 7:08 AM UTC
I’ve ran into the same issue. I was so excited to finally get a grid functionality, but it’s still miles away from the actual `display: grid` in CSS.
In CSS, you can define `grid-template-rows` to have values like `auto`Ā (automatically resize to fit children’sĀ height) or fractional units like `1fr 4fr`, which would tell the grid to have the 2nd row four times taller than the first.
The current functionality of grid in Figma is so lacking that I’m still forced to use nested flexboxes or wrapping.
This. I imagined grids would work like they do in CSS and finally replace the need for nested auto-layout frames in Figma. Rows and columns should accept hug and min/max values, without it we’re left fidgeting with the numbers or simply continue using nested frames to handle layout grids.
I hope this makes it in the next update šŸ¤žšŸ¼
Claire Paoletti
May 22, 2025 8:45 AM UTC
I’ve ran into the same issue.Ā
Purrgil
May 22, 2025 12:36 PM UTC
The new grid function is so bad and is worse than the previous verison.
Tiziano
May 27, 2025 2:50 PM UTC
Figma Grid is missing the option to input a variable in the gap field:
Ā
We need to be able to give this parameter a Token.
May 29, 2025 6:37 AM UTC
Hi ​@Tiziano,
Ā
Thanks so much for reaching out and for taking the time to explore our newly released Grid.Ā We’re excited to see your early engagement and value your feedback.
Our Engineering team has reviewed this closely and confirmed that the behavior you’re seeing is a known issue. The good news is that it’s already on our radar and has been prioritized asĀ future release.Ā
I’ve also personally shared your feedback directly with our Product and Engineering teams for future improvements. So, let me change the category into ā€œSuggest a featureā€.
We’ll keep you updated as we make progress and will share more details as soon as they become available. In the meantime, feel free to reach out if there’s anything else I can support you with.
Ā
Thanks again,
Toku
Grant_Galtney
May 30, 2025 7:00 PM UTC
Ā
this is definitely a tablestake that should have shipped
