Jerimy_Brown1
January 4, 2023
[LAUNCHED] Paragraph spacing settings break when mixing styles in single text block
Paragraph spacing breaks if you mix text styles in a single text block.
Ideally this would function in such a way as to take on the paragraph spacing per style instead of assuming everything in a given text block wants to use the same paragraph spacing.
If the paragraph spacing was inherited by selected items, the same way the rest of the text style is, it would make quick single text block styling possible…
Right now you have to create individual text blocks every time the style changes and then merge them with an autolayout, then if you want different spacing you end up with a bunch of embedded autolayouts, which works, but it’s messy.
Przemyslaw_Cioch
January 5, 2023
Fully Agre. It took me a while to understand what’s going on there. It should work like in any other tool.
Penina
January 10, 2023
I was so sure I was doing something wrong (“this couldn’t possibly be Figma!”) and thought it would involve a quick search in the community. Now I just hope this is not too far down the roadmap/fixit list…?
Jeff.Miller
January 13, 2023
10,000,000%. Figma is fundamentally broken in this respect.
Dominic
January 24, 2023
Definitely a major issue. I’ve tested it to exhaustion and when using text styles paragraph spacing simply doesn’t work!
Milovan
January 26, 2023
I still have same problem with paragraph spacing…still nothing?
Janessa_Hayven
February 6, 2023
Paragraph spacing never works! Can someone please help??
Shevchenkoserj
have the same problem
Shevchenkoserj
ive found the thing i need in list spacing
AddWeb_Solution
February 22, 2023
Hello,
You can adjust the top and bottom margins of the text box by using the “Paragraph Spacing” controls in the properties panel.
March 25, 2023
No you can’t. It doesn’t work. That’s our point.
