Arvid
Feb 6, 2021 1:33 AM UTC
LAUNCHED: Nested variant component override controls
it would be nice if the inspector would list overrideable / swappable nested components without one having to drill down into the component’s layers.
This would allow to quickly select multiple components and change an override for all of them. Currently I have to click through the relevant layers of all marked components to adjust the overrides in bulk: E.g. changing an icon override for multiple components.
matt23
Dec 9, 2021 4:46 PM UTC
We’re building an atomic design system. One thing that has come up multiple times that would be really nice to have is the ability to control the variants/overrides of nested components.
For example, we have a button component that uses variants and variant properties to control button size (sm, md, lg), button state, whether it has an icon or not, etc. To keep the system atomic we then nest that button component in other components, for example, a header component. But we want to limit the header component to only accept sm buttons and not md or lg while keeping other variant attribute overrides intact like state.
Could there be a similar locking mechanism like how locking a nested component will block any overrides at all, could we somehow lock specific attributes? for example lock the variant attribute for size.
Federico_Romano
Dec 9, 2021 6:22 PM UTC
Thanks a lot @Gleb this is AMAZING! you were so fast on building this, how do we push Figma to incorporate this natively?
Federico_Romano
Dec 9, 2021 7:56 PM UTC
that doesnt sound like this feature request at all, try opening a new thread for that, this is for enabling editing nested variant properties in the same panel, and luckly, its progressing
matt23
Dec 10, 2021 3:38 AM UTC
It was a new thread but it was moved into this thread for some reason.
Power Member
Dec 10, 2021 4:06 AM UTC
Sorry for the confusion, the title is pretty much the same to this topic, so it was merged. I just reopened your topic. I would suggest writing a title that better reflects the idea, like “Limit override options of nested components”.
Klesus
Dec 29, 2021 1:33 PM UTC
I have an idea that is relevant to this so I’m not sure if this should be a separate post but I’m posting it here for now.
OP have asked for controls for nested variants overrides, but I would like to be able to expose any overridable property of my choosing to the top level parent, not only variant options.
Consider something like using spacing to create a variable progressbar. It’s technically possible to create one with only 1 depth of nesting, allowing the spacing to be controlled from the top in the hierarchy. However, this requires overflowing content so this component can’t be used in an autolayout without overlapping neighboring objects. The solution is to wrap it inside a frame but then the spacing property disappears from the root parent. Aarrgh.
And this is only a simple progressbar. More complex components would include a mix of overrides, like spacing, visibility, color, etc. and of course variants as already discussed.
Being able to put these controls to the front would make it possible to create more intuitive design systems. Now you’d need to create a tutorial for those uninitiated.
It could work by choosing to add a property from a context menu:
or maybe even quicker to add it with a ctrl/cmd+click.
Then it would appear on the component root layer, just how the solution functions for this topic. But it would be great if it also were possible to rename the property to better communicate what function the control serves in the component.
I really wish something like this can be done.
Ilya_Lowda
Feb 8, 2022 4:26 PM UTC
Hello! As I told in another one topic I am trying to create most detailed and automated design-system as I can create. This is a kind of challenge to me 🙂
I have really big super-nested components. With 6-7 nests. And I want to set-up their attributes on a main component, that will include all the attributes from all nests of that component. Uff, I know sounds crazy, let’s see an example:
Just FYI this is just a 2 nests of 1 component.
So I have this component that have 3 attributes on the right panel
Then this component is using inside of this component that have a 1 attribute:
But the problem that on this step I want to see the attributes of the nested component. I mean finally I want to see 4 attributes, not just one. Because it is legacy and on final step I want to see all attributes on each nest on the final component
You will ask what kind of problem are we solving? So I don’t want to create all variations of nested components in the final component
Sorry for my English, I hope that anybody could understand what I mean 🙂
P.S. And why you can’t allow new users to send more images in one post. I could upload more screenshot to make this topic more understandable 😃
Thank you!
rahendz
Feb 21, 2022 6:16 AM UTC
Hi Figma,
Please help me to easily switch variants of components inside a component.
If the component consists of small components then the sidebar also displayed the components in it to make it easier to replace variants for each of those components
Federico_Romano
Feb 21, 2022 2:30 PM UTC
Did you read this topic? there is already a plugin developed by @Gleb based on the discussions of this forum that works like a charm, please read this post, not just write something at the end
rahendz
Feb 21, 2022 2:53 PM UTC
Thanks, @Federico_Romano. I post this because I need a native feature. Turns out that there is another person who posted a topic with the same issue, and my post ended up moving to here. And yes, there is a plugin made by @Gleb and I use it. But just like I said, hope there will be a native feature on Figma just like the sketch.
Thanks for replying to my post, Fed. And cheers to Gleb
