Anton_Bahrencheer
Jun 21, 2023 8:57 PM UTC
LAUNCHED: Moving or copying variables
Has anyone found a way to copy, transfer or move the new local variables to another file or collection?
Just created around 400 color variables manually in the wrong file and would hate having to re-create them in the correct one 😅
Cindy_Wong1
Oct 4, 2024 5:15 PM UTC
Hi Celine,
Thanks for the update that allows us to copy-paste local variables. Though this is helpful for one-off local variables, it is still a manual solution that takes longer the more local variables you have. Would still prefer being able to move variables from one library to another using the cut/paste method - I voted for this feature request.
When I first tried to go step-by-step with the Help Center article, I struggled to find where the variables were after I pressed ‘Copy variables into this file’ from the toast notification. When I clicked ‘Local Variables’ from the right sidebar, it was empty. It wasn’t until I noticed that there was a new Collection on the dropdown menu that I realized the variables were copied over successfully. I suggest making it more clear that there are updates to the variables panel - perhaps with a blue badge similar to library updates.
Thanks!
Julia57
Oct 8, 2024 7:55 AM UTC
Hi, it seems this is no longer working…? I dont get any new collection, or the popup that used to ask if i want to copy the variables over. Now nothing happens.
Oct 8, 2024 9:37 AM UTC
Thanks for your feedback @Cindy_Wong1 , we will share it internally.
@Julia57, this looks odd, we are not aware of this issue. If this still happens, I’d recommend you to reach out directly to the support team so we can take a look at it further: here
Be sure to use your Figma email account, include a quick video recording when you encounter the issue, share the URL of the file and add support-share@figma.com as an Editor in your file, so we can take a closer look. Thank you!
David_Leman
Oct 16, 2024 8:17 AM UTC
There is a great and cheap plug-in to help doing this - it can also add a lot of value for exporting and bulk editing variables. It’s a one time cost to get the plug-in. Of course would be great if its part of Figma, but until them I recommend this.
https://www.figma.com/community/plugin/1285971940276913396/heron-variable-tools
Nov 13, 2024 12:05 AM UTC
Hey All,
We just launched the ability to copy and paste variables across collections! 🚀
x.com
Jim_Knox
Nov 26, 2024 11:35 AM UTC
Thanks, this will help alot
Joe_Thomas1
Nov 26, 2024 5:32 PM UTC
It really should just be move not copy. I don’t need to duplicate all the variables. I need to move and reorganize them without breaking any links.
ScottDaniels
Nov 26, 2024 6:05 PM UTC
Both options should be available, as its also nice to be able to copy across files, create new similar variables, etc…
Move or Copy/Paste.
craig_willers
Dec 3, 2024 10:24 AM UTC
When I paste variables to another file they paste is a random order. Is it possible to fix this as it’s proper annoying.
Oh, and make it so you can reorder them properly rather than having to figure out dragging them in arse about face manner.
Buggy!
Alex_Stoian
Dec 17, 2024 9:21 AM UTC
+1, I really need a way to move every variable from one file to another. I have to consolidate hundreds of variables and this process is insanely time consuming right now. At least have them paste to the new file in the same order they were copied!
