Cody_Porter
Jan 22, 2021 7:19 PM UTC
LAUNCHED: Min and Max Width for Auto Layout
I would like to add a max-width to a text box while using auto layout to keep the word count per line at a reasonable minimum.
Currently, I have the text element set to “Fill Container” which makes the text respond very nicely to the screen size. But because it is set to “Fill Container”, the text spans the entire width of the element which makes the text lines more difficult for users to read quickly.
If a max-width was set, the component should respond until it reaches the max-width, which would help keep the line length down.
I also feel like there are many other circumstances where max and min-width would be extremely helpful
Anyone else having this issue? Or does anyone have a great fix/hack to get around it?
Looking forward to seeing what you have to say.
Cheers,
Alex_Wright
Mar 14, 2023 8:57 PM UTC
Yes!! This would be so incredible!
Kevin_Hannon
Mar 21, 2023 5:52 PM UTC
I vote a big “YES” for Min/Max values! Please make this a reality ASAP, thank you! ❤️
Franciny_Morales
Mar 21, 2023 6:19 PM UTC
Set a minimum or maximum height or width for the components. To be able to adjust the component by setting a requirement that it cannot exceed a certain size.
Matthew_Vella
Apr 7, 2023 12:27 PM UTC
+1 for min/max width please. This will be so helpful for responsive designs and developer handoff
Florian_Riviere
Apr 20, 2023 1:50 PM UTC
Yes !!! +1 too
Florian_Riviere
Apr 20, 2023 1:57 PM UTC
And this line break in the auto layout part 🫣
Apr 21, 2023 4:46 PM UTC
Vincent. I made the min width work in a couple different ways using the hidden line. In the case of a button with an icon (and all non-2 action) set the line as its own frame under the frame that contains the text and icon.
Regina_Casaleggio
May 24, 2023 2:22 PM UTC
Figma has made a lot of progress in making the design/dev handoff easier and bring design and/dev closer than ever before. Having min/max width and height would be another step closer.
My use case at the moment is for min-heights on things like buttons, inputs etc That way I don’t have to rely on line-height and top/bottom padding to get the desired height and still have a button text that can wrap.
NorItu
Jun 30, 2023 10:14 AM UTC
You got what you wanted in the end <3
Jul 3, 2023 2:41 PM UTC
