May 30, 2024 10:23 AM UTC
Importing Draw.io files
I know that I can export as SVG from draw.io and then drag and drop in FigJam but this does not allow me to edit. I would like to import a flowchart from draw.io in an editable format. Thanks.
MarleenH
Dec 9, 2025 10:12 AM UTC
+1
sstarr1879
Dec 9, 2025 3:28 PM UTC
+1
alen.kovacevic
Dec 31, 2025 7:17 PM UTC
After exporting from Draw.io, I was able to import the UML diagram as a PDF file. It's not perfect, but it can be edited.
Maher1234
Feb 23, 2026 8:51 AM UTC
+1
Sean Cummins
Mar 2, 2026 4:39 PM UTC
+1
theabhishekar
Apr 9, 2026 1:55 PM UTC
Hey Nawaal_Waggie and everyone,
I ran into the same issue when trying to import files from Draw.io into FigJam SVGs look fine but aren’t really editable.
To solve this, I built a simple plugin called “Draw.io to Figma” that makes the process much smoother. Instead of using SVG, you can export your flowchart from Draw.io as a CSV file, then import that directly into FigJam using the plugin. The elements come in as editable components, so you can easily modify and rearrange them inside FigJam.
It’s been working really well for me, and I hope it helps you too. Let me know if you’d like a quick guide on how to use it!
You can try it out click here: Draw.io to Figma
