harsha20599
Mar 15, 2021 6:39 AM UTC
Import EPS into Figma
There is lot of market out there which provides illustrations or assets in the form of EPS. (for example, freepik assets).
Prototyping tools like sketch already supporting the EPS file and it’s easy to use them inside it. But Figma lacks the support of it and I think we should have that in the near future.
Do you guys know any workaround to import the eps into figma ? I am preferring a free approach because illustrator and sketch are paid tools.
Power Member
Mar 15, 2021 8:14 AM UTC
The only vector format Figma accepts is SVG, so the easiest (only) way is to convert EPS to SVG (there are tons of apps and online converters) and import it into Figma.
Willi_Maese
Jan 26, 2022 4:05 PM UTC
Agreed, it would be very nice to have EPS support.
Nitesh_Jamod
Feb 17, 2022 4:30 PM UTC
Agreed too!
vtao
Mar 11, 2022 5:34 AM UTC
Unfortunately, I couldn’t find any online free tool that can convert EPS to other formats properly. After converting, the file became blurry, if Figma can provide this feature that will be great!
Rakesh_Ameta
Apr 2, 2022 2:43 AM UTC
  1. If you want to convert a few files a lot of online free sites there.
  2. If you want to convert locally on your laptop Inscape & Photopea are the best free options, these are quick also specially Photopea.
Still, if Figma provides it directly, it would be great time saver.
Noradavis
Apr 2, 2022 7:25 AM UTC
As you may know, you cannot directly import EPS or AI files into Figma , but you can use another cps tester software as a bridge for this purpose and Inkscape is the perfect one Currently, Figma cannot import/process Adobe Illustrator (ai) files . Designs have to be converted by following either of the four paths: Open an Illustrator file Copy or drag everything to Figma.
Pawel_Borkowski
Apr 14, 2022 3:54 PM UTC
Kevin3
May 23, 2022 5:10 AM UTC
We’ve worked on a EPS to Figma converter and you can now access it here: Convert & Import EPS files in Figma
It’s paid but we made sure the results are super accurate and all text elements and path elements are preserved. Good luck y’all.
Donna_Vitan
May 26, 2022 10:00 PM UTC
I’d like this very much. Please and thank you.
Vladan_Zlatic
Jul 2, 2022 3:50 PM UTC
EPS to SVG converter that works 100%. I’ve tried bunch of online converters but found only this one that actually convert’s without distorting the shapes: Convert EPS to SVG Online
