ShaKalua
May 19, 2025 7:01 PM UTC
Hiding the Quick Create Toolbar
I’m not sure if this is possible, but could you make a feature to hide the quick create toolbar on FigJam? It’s constantly in the way of what I’m trying to see and for some reason the tool bar doesn’t have a move feature. I would greatly appreciate the adjustment, although I know Figjam is still fairly new. I’ll also be posting to the community to see if anyone has found a work around.
    Raphael_M
    Power Member
    May 20, 2025 3:55 AM UTC
    There’s a work around, but I suggest not to close the window but instead minimize it so you can still toggle it on and off. In case you closed it, you have to restart the file or your Figma.
    ShaKalua
    ShaKaluaAuthor
    May 20, 2025 1:04 PM UTC
    I super appreciate your help but unfortunately I was talking about the black tool bar the pops up when you select an object. I believe it was called the Quick Create toolbar but I couldv’e mislabeled it. By chance, would this also work for that tool bar? 🥹
    Raphael_M
    Power Member
    May 21, 2025 1:16 AM UTC
    Try targeting this class:
    It works on my side, but I’m not sure if there are other Figma components that would be hidden.
    ShaKalua
    ShaKaluaAuthor
    May 21, 2025 9:47 PM UTC
    Thank you so much for your help. I think you might be right that there are some hidden sections, I attempted to find the tool bar following the video guide but was only able to edit the main toolbar at the bottom of the screen. However, I’m very grateful for your help, you coding genius, and hopefully the Figma dev team will work on it!
