Rozerin
Jan 14, 2026 8:52 AM UTC
Grid container with Hug Contents doesn’t resize when content is hidden
Hi all 👋
I’m working with a Description List component built using CSS-like grids in Figma (term + description per row).
Each row is sized to its content, and the overall component height is also set to hug contents.
However, when I hide a row (e.g. term + description), the container height does not automatically resize to the remaining visible content.
Instead, I have to manually resize the container, and I end up seeing purple grid lines below the visible content.
What I would expect (and what I’m used to with other components) is that the container immediately shrinks when content is removed or hidden.
Questions:
  • Is this a known limitation when using grids in Figma?
  • Has anyone found a workaround for this?
  • Or should this be considered a feature request so hidden grid rows no longer affect container height?
Curious if others have run into this as well 🙂
I’ve attached a short video showing the issue:
Thanks!
