Nov 14, 2023 11:47 PM UTC
Fully Editable Object (Frame) Inside a Component Instance
Different than having a fully editable component instance, I would really like if there was a new object type (or maybe the frame object could be extended) so that it could serve as a fully editable space within a component. So basically when I use an instance of that component, I can populate this editable container with anything I want, and still retain the relationship to the original component (not having to detach it).
My current workflow has me nesting a “content area” component instance into the a larger component (think page layout, card, modal, etc), and then creating my custom content as a separate component and doing an instance swap to get my custom content into that larger component. It’s either this, or just detaching the larger component and putting my content inside of it, which then defeats the purpose of having that larger component and then it’s just acting a template.
This has bothered me for years and I searched for a solution to/request for this and can’t believe I’m the only one that has ever needed something like this? Hopefully not…
Nov 15, 2023 6:39 PM UTC
Hey @Ryan_Crippen, thanks for the feedback!
We’ll pass this onto our team for consideration.
ThatOneGuy
Mar 7, 2024 2:29 PM UTC
This is exactly what my team needs for our design system UI kit. It would open up the possibility to create larger components (e.g. layouts and other predefined wrappers). See the example below for an instance of a popup that can have different types of content. Currently we ask our users to create a local component next to the popup and populate the content slot, but this is a unfortunate workaround.
Screenshot 2024-03-07 at 15.28.04
armproducer
Sep 17, 2024 11:13 AM UTC
Hello @dvaliao! Do you have any news about this cool feature? Does team working on it or going to work?
Mayumi_Niino
Jan 22, 2025 12:34 AM UTC
Hello!
Could this functionality correspond to the ‘Exsamples’ found in the component systems distributed, such as iOS18?
Instances dropped from ‘Exsamples’ are frames and can be modified!
I would like to know how to create this
https://gyazo.com/b3a0d105849c1a65d95082ed39d24998
