Fernando_Lins
Feb 29, 2024 5:41 PM UTC
Font Weight in Numbers on the Design Panel
Currently Figma only shows font weights as Thin, Regular, Medium, Bold, Black, etc. on the Design Panel, and you can only see the actual value of the weight in the inspect panel, but it would speed up design spec work and documentation work a lot if in the Design panel, next to each weight it also showed the value for that weight, as in Thin (100), Regular (400), Medium (500), Bold (600), and so on, as it is what tokens should use and developers would implement most often.
Mike_Turiano
Jan 21, 2025 5:23 PM UTC
Adding another vote for this feature. Developers use numbers for weight, not names. This is actually impacting our ability to accurately represent reality in our Figma designs.
Mike T
Alexander Lall
Feb 4, 2025 11:22 AM UTC
Adding another vote. It is a limitation. Strongly agreeing with Mike_Turanio.
Daren Cocker
May 23, 2025 2:55 PM UTC
This is easily resolved by going into DEV mode and then drilling into the font typography. This will give you the exact details.
