Lucia_Carroll
Apr 8, 2025 5:36 PM UTC
Figma Slides: Adding links to images
Hi! I’ve noticed that I’m only able to add links to text. It would be really great if it were possible to add links to other objects, specifically images.
Jesse_Wallace
May 7, 2025 5:42 PM UTC
Yes, we absolutely need to be able to add links to any other object: component instance, group, frame, image, etc.
Pops
May 9, 2025 6:43 AM UTC
Hi I just found this solutions!
You could using prototype. Click image or icon or other objects that you want to add link then change to prototype and add interactions and select the trigger on click and choose action “Open Link” then finally paste your link .
Hope it helps!
Kreation V2
Feb 9, 2026 11:31 AM UTC
Hope it helps!
can you explain this workaround further? you mean i have to create a prototype in advance and embed it then into figma slides? i can’t find a direct solution “change to prototype” when placing and image and selecting the object. thanks!
Tashfix
Mar 15, 2026 8:17 PM UTC
You can use the plugin "Universal Hyperlinker"and it will hyperlink images, frames and shapes in one click right on the canvas. Not just in prototype mode.
