Tom_Stimpson
Jun 20, 2025 11:44 AM UTC
Figma MCP - reading variable modes
I’ve been looking into how I can leverage the new MCP server functionality in my design-to-dev handover process, but have been struggling with a few issues.
As a means of speeding up my web design process, I have created singular components (no variants) that use variables for spacing, typography etc. These variables relate to modes like Wide Desktop, Desktop, Tablet, Mobile.
My idea is that I’d like the MCP to read the singular component and be able to extract all the variables information across all modes and map those values to Tailwind classes (such as pt-4 md:pt-6 lg:pt-8 etc..)
With a fair bit of back-and-forth, I’ve been able to recreate a passable version of my designs, but only for a single instance - this using variables from the default/first variable mode. So it’s not ideal to select one frame/screensize at a time and prompt the agent to recreate it - the code output can get messy pretty quickly.
Do we know if there if Figma have release plan for the MCP to be able to read multiple variable modes in the near future? This would save refactoring my variables into a single mode - and would also require that I make multiple variants of a component so that each screen size is catered for.
If not for a Figma-based update, has anyone had similar frustrations and do you have any workarounds?
Thanks!
Yarden K
Jun 27, 2025 9:55 PM UTC
It is definitely in our list!
Darren N
Oct 30, 2025 1:05 AM UTC
I feel like this is the same issue I’m having, viewport is one set of ‘mode’ and ‘theme’ is the other.  And it would be great if MCPs could get a list of those, and then switch those when pulling variables.
Right now it looks like we’re forced to dump all variables, follow the path of variables, to then just pull out the x theme amount of colors.
Otherwise get_variable_defs seems to only ever give the deafult values.
AllanLowson
Jan 16, 2026 5:43 PM UTC
Is there any movement on this? I too have set up light and dark modes using tokens and variables, but they seem to be inaccessible from the MCP. Is there a way to export the entire variable set with modes?
Valentin Seehausen
Jan 29, 2026 5:18 PM UTC
Hey guys, this is such a basic feature. You are forcing users to manually sync variables from Figma to code. It could be so easy with MCP. Why aren’t you adding this? I can make a 10 day intern and add this feature if nobody on your side can do it.
Anni_V
May 25, 2026 5:13 PM UTC
Any news on the fix? I am about to introduce my team to the MCP server and just ran into this problem while coming up with a demonstration. Embarrassing. 💀
Luism
Oct 22, 2026 4:03 PM UTC
Same gap here. Our typography collection has Desktop (default) and Mobile modes, and get_variable_defs and get_design_context always resolve Desktop. Neither tool takes a mode argument. Agents building mobile screens read desktop type sizes (24/28 instead of the Mobile 20/24 for one heading style), and the only workaround is a rule telling them to ignore Figma's numbers.
Ask: a mode parameter on both tools, or the mode a frame sets explicitly when it overrides the default.
