Jul 1, 2025 5:12 PM UTC
Figma Make - switching from shadcn components to our actual design components
How can we specify the design component code that the AI should be using?
In the Attributions.md file, it says:
This Figma Make file includes components from [shadcn/ui](https://ui.shadcn.com/) used under [MIT license](https://github.com/shadcn-ui/ui/blob/main/LICENSE.md).
We don’t want an AI’s transformation of shadcn components into what looks like our design components. We want to use our actual design components to limit the number of ways the AI can miss interpret the designs it is prototyping to reduce variation errors between prompts.
For example, I can give the AI the same prompt, and it will give me different designs when it’s re-interpreting the shadcn→design components every time.
Generating code that is already aligned with our design components is also more useful for engineering workflows to convert the prototype into PR’s.
It should also import the guidelines file properly from the design library. I don’t think this worked for me.
Between the attributions and guidelines being imported properly from our design system, we’re hoping Figma Make will become more useful!
jeevan k poojary
Jun 18, 2026 4:32 AM UTC
Can we actually do that ? like use our design system/components  in the place of Shadcn ?
Maxym
Jun 27, 2026 12:05 PM UTC
A useful workaround could be giving AI a clearer visual system before generation. VisualSnag turns references into CSS variables, design tokens and structured prompts, which may help with shadcn-style workflows: https://www.visualsnag.com/
