Chris Rickey
Jan 6, 2026 7:23 PM UTC
Figjam: highlight all connectors from an object
I would like to highlight all the connectors from a given object in Figjam.
For example, if I have a block that has several connectors coming into and out of it to many other blocks, right clicking on the block and “highlight all / highlight incoming / highlight outgoing” options. It would make all the other connectors on the screen transparent or greyed out so that I can easily see which objects are connected to my object and how its connected.
Jivy
Jul 30, 2026 5:02 PM UTC
Hey Chris — I had the exact same need and ended up building a plugin for it called Focus Pocus.
It does pretty much what you described: select any object, run the plugin, and everything that's not connected to it fades out (connectors and nodes). You can control how many hops to trace (1, 2, or 3) and set the dim opacity level.
It's on the Community if you want to try it out — there's a 3-day free trial so you can see if it fits your workflow.
Would love to hear if it covers your use case or if there's anything missing!
