Joseph_Cooper
Apr 21, 2021 7:04 PM UTC
FigJam connectors in Figma
When creating hand-off documents I like to showcase user flows by using arrows between different UI elements. I have to use plugins to create these arrows at the moment. When playing with Figjam I notice it had a connector option - this is great. I would love it if we could also have this connector option inside Figma as it would be a HUGE timesaver for hand-off.
I would like to think this would be a super easy update given that we can already edit connectors inside Figma. We just need a connector button in the toolbar like so:
Briston
May 2, 2025 12:57 PM UTC
If you're looking for a way to bring FigJam-style connectors into your Figma workflow, I’ve built a Figma plugin for that.
https://www.figma.com/community/plugin/1497662430674423590/flowconnect
  • Set any connector source you want within your Figma file
  • Add text labels to your connectors
  • Customize the style of each connector
  • Connect any two objects—components, instances, or anything else
  • Switch easily between elbow, straight, and curved connectors
  • Smart arrow switching when objects move
  • Save presets and use it whenever needed (Premium)
Frank_K
Jul 17, 2025 10:32 AM UTC
I tried to copy some shapes and connectors with text to Figma and find that they’ve added node types for these two: CONNECTOR and SHAPE_WITH_TEXT, these types are not in plugin documentation yet.
I think Figma will add support for connectors and shape_with_text to Figma officially in the next updates.
I was trying to add RTL Support to the connector label for RTL PLZ Plugin, but its node properties are incomplete and I hope they provide characters property or something like that to allow updating connectors label with the plugin.
Sadly years on and still no connector lines :(
Jefferson Costa
Jul 17, 2025 5:39 PM UTC
Instead of implementing a useful feature, they go and add a glass effect. Congrats, Figma 👏🏻👏🏻
Frank_K
Jul 18, 2025 9:10 AM UTC
Much like the poorly implemented annotation cards recently (I built my own components for this in about 5 minutes and they work better!) The crazy thing is you can copy figjam connector lines into your design files so all they need to do is enable them as a component.
Pedro Ivo
Aug 5, 2025 11:22 AM UTC
I’ve been an avid “Give me Figjam Connectors” plugin user in the last few years and I’m very sad to report that all plugins that used native Figjam connectors stopped working once Figma updated their API.
I think it’s about time that this become a native Figma feature. This was by far the most used plugin I’ve ever used to document and share with Developers how apps worked.
Personally, I’ve used Figjam connectors because it gave me the option to quickly link to screen by using the shortcut cmd + p and typing “Add connector”.
Lehel_Babos1
Aug 10, 2025 11:40 PM UTC
The fact that Figma hasn’t implemented this after YEARS is nuts. But they also recently broke more or less every plugin that was at least helping us fill this gap. Great. Sure glad we got glass effect in the effects menu now tho 🤙
Wendy3
Aug 11, 2025 12:30 PM UTC
Anton_Andrianov2
Aug 12, 2025 4:17 PM UTC
Figma, please add connectors as a standard feature in Figma (like as FigJam)
You're adding a lot of great features to Figma, but you're still not adding such a simple and much-needed one. Why is that?
Designing flows in Figma is currently very inconvenient. Even Pixso has had this feature for a long time already
Anton_Andrianov2
Aug 12, 2025 4:21 PM UTC
Even Pixso has had Connectors for a long time already. Figma is no longer the same as before =/
Harri_Granholm
Aug 20, 2025 2:01 PM UTC
This would be the biggest time saver ever, forget about AI. I’ve wasted so many hours editing flow connectors manually… Please do it 🙏
