UI_Designer2
Oct 3, 2026 5:52 AM UTC
Feature Request: Support Percentage Values for Line Height in Figma Variables
Problem
Currently, Figma Number Variables do not support percentage values for line height. This makes it difficult to create a consistent and scalable typography system using variables.
Many designers prefer to define line height as a percentage relative to font size rather than using fixed pixel values. For example, a heading might use 125% line height, while body text might use 150%.
Suggested Improvement
Please add support for percentage values in Number Variables, especially for typography properties such as line height.
This would allow designers to create reusable variables like:
  • line-height/tight — 120%
  • line-height/normal — 140%
  • line-height/relaxed — 150%
Designers could then apply these variables directly to text styles and maintain consistent typography across their design systems.
Benefits
  • More flexible and scalable typography systems.
  • Easier consistency between font size and line height.
  • Better support for design tokens and design system workflows.
  • Improved collaboration between designers and developers.
  • Less manual work when updating typography across multiple components.
Supporting percentage-based line height variables would make Figma's variable system more powerful and align it better with common typography workflows.
Would love to see this feature in Figma!
Fiskbulle
Oct 8, 2026 1:48 PM UTC
I tried setting up a new project using Claude, Figma, and Tailwind. It seemed like a very logical setup: the Figma design serves as the single source of truth and is directly linked to the styling framework.
A designer creates a design that is translated into HTML based on a design system built using Tailwind tokens in Figma as variables. To my surprise, however, issues with line-height and font weight rendered the entire attempt unusable :D
It’s embarrassing; after all the hype surrounding variables and Figma MCP servers, it was the simplest thing that didn’t work.
While we’re at it, looking into text styles might be a natural next step. There has to be a simpler way to set up a design system with text styles that utilize variables and support export and import.
You cannot expect a team of designers to always choose the exact right style or color every time they create a component or layout. It would be practical to use something like Tailwind for foundational tokens, and build a set of typography and themes on top of that, using styles that reflect the brand. Easy to export and import :)
