Jan 28, 2026 4:31 PM UTC
Feature request: Add a way to clear or manage Figma Make prompt history (memory / performance issue)
I’d like to suggest a feature improvement for Figma Make based on a real issue I recently encountered.
In one of my long-running projects, I had accumulated thousands of Make prompt interactions (≈4,000+) over time.
Eventually, the file began to show severe performance issues:
  • Frequent “Recovery mode” prompts
  • Editor becoming unresponsive
  • Out-of-memory (OOM) crashes
  • Make prompts failing with errors such as
    POST /api/make/fetch_ds_code_gen_status 400
After working with Figma Support, we discovered that clearing the Make chat history immediately resolved the problem:
  • Performance returned to normal
  • No more recovery mode or memory crashes
  • Make prompts started working reliably again
This suggests that long Make prompt histories can significantly impact memory usage and file stability, especially in large or long-lived projects.
Feature suggestion
It would be extremely helpful to have:
  • A built-in option to clear Make prompt history
  • Or basic prompt history management (e.g. clear, archive, limit history length)
  • Ideally with a warning that the action is irreversible
This would:
  • Prevent memory-related issues before they occur
  • Give users control over file health in long-running projects
  • Reduce support cases related to unexplained Make crashes or recovery mode loops
Make is a powerful feature, and this small addition would greatly improve stability and usability for heavy or long-term users.
Thanks for considering this, and happy to provide more details if helpful.
Dan208937u39qythobgaoerh
Jan 28, 2026 7:07 PM UTC
This is absolutely essential, people, I cannot understand how you go to market without simple guardrails in place. wtaf
Jan 28, 2026 7:10 PM UTC
Dog. This is bonkers.
Coils
Feb 6, 2026 12:48 PM UTC
Is there any way to do this, or do we need to go through Support to reset the conversation? It could be useful in many cases, as I’ve notices hallucinations in some of my projects.
Feb 6, 2026 12:56 PM UTC
There’s currently no self-service way to clear Make prompt history.
The only solution I found was to contact Figma Support and ask them to reset/clear the Make conversation history for the file.
After Support cleared it for me:
  • Performance issues disappeared
  • Recovery Mode stopped
  • Make prompts started working normally again
If you’re seeing crashes, recovery loops, or hallucinations, I recommend opening a Support ticket and explicitly requesting a Make history reset.
Coils
Feb 6, 2026 2:40 PM UTC
Thank you for the answer.
If I continue using Make rather than switching tools, I’m sure to run into this problem eventually. Will keep this in mind, and if they get enough of these requests I imagine they implement your original request.
Feels like Make is still in it’s infancy. Here’s hoping it grows into a proper tool.
