Kevin Hoogkamer
Aug 24, 2026 8:59 AM UTC
Expose stable component identity for instance swap properties in parserless Code Connect
# Expose stable component identity for instance swap properties in parserless Code Connect
## Problem
When using parserless Code Connect templates, `getInstanceSwap()` returns an `InstanceHandle`
whose `symbolId` represents a file-local component node ID.
The same library component can have multiple local aliases in a consuming Figma file. For example,
one icon may appear under these IDs:
```text
5:154       Library component ID
11221:2421  Local alias
12041:6322  Another local alias
Although all three represent the same library component, Code Connect only exposes the local
`symbolId`. This makes it difficult to translate an instance swap into framework-specific code:
```ts
const icon = instance.getInstanceSwap('StartIcon');
const iconName = iconsBySymbolId[icon.symbolId];
A manually generated mapping must currently:
1. Download the source library and consuming Figma file.
2. Match components using their stable component keys.
3. Discover every local alias for each component.
4. Generate a lookup table from every possible `symbolId` to its code representation.
5. Regenerate and republish whenever new aliases are introduced.
Without this mapping, valid swaps produce unknown values even though they reference a known library
component.
## Requested solution
Please expose a stable identity for swapped component instances, preferably the library component
key already used internally by Figma.
For example:
```ts
interface InstanceHandle {
  readonly symbolId: string;
  readonly componentKey?: string;
Code Connect templates could then use a stable mapping:
```ts
const iconName = iconsByComponentKey[icon.componentKey];
Alternatively, `getInstanceSwap()` could return source-component metadata:
```ts
icon.sourceComponent = {
  key: 'stable-library-component-key',
  nodeId: '5:154',
## Possible higher-level API
A native value-mapping API for instance swaps could remove the need for custom lookup logic
entirely:
```ts
const startIcon = instance.getInstanceSwap('StartIcon', {
  mapBy: 'componentKey',
  values: {
    '<stable-component-key>': '@Icons.Material.Outlined.AutoAwesome',
## Expected benefit
This would make instance-swap mappings:
- stable across files and component aliases;
- independent of local node IDs;
- easier to maintain and publish;
- reliable for icons and other swappable library components;
- consistent with Figma's existing stable component-key model.
