Joshua_Harwood
Sep 14, 2025 10:53 PM UTC
Enable Figma design URLs in Figma Make prompts
Enable Figma Links (page/selection/node) in promptsĀ for Figma Make.
  • Figma Make should be able to connect to our design files and reference the design instead of relying on an image.
  • Using Figma URL into Make and it can read the structure and styling directly
  • Figma Make should be able to detect Code Connect (like MCP) and use React components
koxikawa
Aug 17, 2026 6:18 PM UTC
I completely agree. Figma Make should support direct Figma page, selection, and node links so it can read the actual design structure, styling, variables, and components instead of relying on screenshots. It would also be valuable for Make to detect Code Connect mappings and use the corresponding React components automatically. A similar URL based workflow can be seen with Bulk URL Opener, which makes working with multiple links more convenient. This would make design to code much more accurate and significantly reduce the need to recreate components manually.
