Antoine
May 19, 2022 12:11 PM UTC
"Empty" Auto Layout Frame keeps the size of last hidden child
Hi, I’m not sure if this is new since the May update, but I wonder why “empty” (all elements hidden) Auto Layout Frames keep the size of the last hidden child (and I do not mean last in the list, but the last element to have been toggled out of view by the user), making them not-0px high even with nothing in them.
See here a file with a Frame with three hidden rectangle: the Frame keeps the size of the last child rectangle to have been hidden. When adding a 0-px Frame to the AL frame, and toggling this 0-px Frame off last, the container goes 0-px.
In my opinion, empty AL Frames should have a height of 0. What do you think?
Pinned Reply By djv
Hey All, thanks again for your continued feedback, and I finally have an update!
As mentioned previously, this is behavior is currently a known feature limitation in Figma. We do not allow Auto layout frames to collapse to 0 when the child layers are hidden, so it is expected that the frame will remain sized as if they were shown.
The team has confirmed that they now have the bandwidth to get this working as expected. In the meantime, they have a temporary solution: Add a visible zero-sized frame. Since the container is then not empty, it will hug to the visible child, which is zero-sized.
While I know this may not be the solution you want, please know that we’re getting closer. I’ll be sure to update you all again once we have a more firm timeline on the fix.
Alamaki
May 16, 2024 6:55 AM UTC
Annoying, but at least it’s easy to work around with a transparent 1px width/height frame in the autolayout.
Diana_Tatarenko
May 29, 2024 1:29 PM UTC
Please fix this. It’s making the use of auto-layout and boolean props impossible to use with complex components.
Stephon_Odom
Jun 12, 2024 2:56 PM UTC
Still struggling with the same issue of auto layout not fully collapsing when all of the layers within it have been hidden. Eager to see what solution is ultimately created by the Figma team 👀.
Joe_Cloughley
Jun 24, 2024 10:53 PM UTC
+1. I am struggling with this issue.
Bert_Selleslagh1
Jul 3, 2024 2:26 PM UTC
+1 also struggling with this still.
lx-zd
Jul 21, 2024 11:55 PM UTC
+1, please fix
Jeremy_Knudsen
Jul 23, 2024 2:46 AM UTC
If you use the Line tool and draw a line with a transparent stroke (do not draw a 1px rectangle as a line), then it should collapse to 0px since lines drawn with the Line tool don’t occupy layout space.
Tascha
Jul 23, 2024 7:35 PM UTC
just dropping in to say this issue still persists… After 1 year with many people having that issue 😢
(0 width object hack luckily is still working tho… (0 width item has to be set to visible with 0 opacity to work & look properly))
Shirley_Wang1
Aug 12, 2024 9:34 AM UTC
Hi all, seems like the bug is not fixed yet, so I too am keeping it alive.
So anyways if anyone need some help, @Tascha 's 0 pixel 0 opacity object is the only workaround
