Antoine
May 19, 2022 12:11 PM UTC
"Empty" Auto Layout Frame keeps the size of last hidden child
Hi, I’m not sure if this is new since the May update, but I wonder why “empty” (all elements hidden) Auto Layout Frames keep the size of the last hidden child (and I do not mean last in the list, but the last element to have been toggled out of view by the user), making them not-0px high even with nothing in them.
See here a file with a Frame with three hidden rectangle: the Frame keeps the size of the last child rectangle to have been hidden. When adding a 0-px Frame to the AL frame, and toggling this 0-px Frame off last, the container goes 0-px.
In my opinion, empty AL Frames should have a height of 0. What do you think?
Pinned Reply By djv
Hey All, thanks again for your continued feedback, and I finally have an update!
As mentioned previously, this is behavior is currently a known feature limitation in Figma. We do not allow Auto layout frames to collapse to 0 when the child layers are hidden, so it is expected that the frame will remain sized as if they were shown.
The team has confirmed that they now have the bandwidth to get this working as expected. In the meantime, they have a temporary solution: Add a visible zero-sized frame. Since the container is then not empty, it will hug to the visible child, which is zero-sized.
While I know this may not be the solution you want, please know that we’re getting closer. I’ll be sure to update you all again once we have a more firm timeline on the fix.
itsViney
Nov 14, 2025 12:34 PM UTC
+1 From me too. Also would be nice to have a ‘Collapse padding when empty’ toggle
Rafa_Moschen
Dec 4, 2025 3:15 PM UTC
Looking for answers here because I am having this issue but a colleague of mine isn’t. Makes me wonder if there is anything I should be doing different.
Seth6
Jan 14, 2026 3:56 PM UTC
I’m also having this issue. Would like to be able to have the frame collapse without having to add anything weird like a third boolean property. It’s limiting the design layout possibilities. Unless I add another variant which is kind of heavy. This is for an enterprise so, the components get kind of big and I want to minimize that if possible.
Seth6
Jan 14, 2026 4:56 PM UTC
Why is your colleague not having this issue? I’d like to know if they found a solution.
Julia57
Jan 19, 2026 8:57 AM UTC
Chiming in here again because I just noticed that fixing this issue would also finally make the AL Grid usable!!
Joseph_Niet
Mar 23, 2026 11:26 AM UTC
Yeah this feels broken when working with grids. I have a 3x1 and I want to toggle one of the cells off with a boolean on the visibility of the cell contents. Even though the cell height is set to hug, when it’s empty it seems to fallback to 1fr?
Hack around it: Add a line with 0% opacity within the frame. Then there’s an element for the height to ‘hug’.
Apolline
Mar 31, 2026 10:16 AM UTC
Same issue with slots now
Enisa Kajtazović
May 20, 2026 1:46 PM UTC
+1
Collapsing an empty frame to a minimum hight, as well!
Kerry_Johnson
Jun 15, 2026 9:39 PM UTC
You guys already have an “Auto layout settings” panel, you should add a new option “Zero height when empty”.  I would imagine you had to write extra code to prevent this behavior from happening naturally, so add another code path that skips that logic.
Julia57
Jun 18, 2026 7:14 AM UTC
​@Kerry_Johnson agree, but I would argue that it should just be the default. I cant think of any reason why I would want it to be not-zero.
