Tricia
Feb 19, 2024 5:27 AM UTC
Disable image border by default when importing images into FigJam
When I export images/photos that were placed in FigJam file, all photos export with this thick white border. Is there workaround so that the images export as if in normal Figma design file, ie, without the border?
Tarver_Graham
Dec 18, 2024 12:45 AM UTC
Thanks for the response Celine. I’m really asking about export here. I can set “transparent” as a border style for exported images, but why not a “none” option? I appreciate that I can copy as PNG, open a Figma file and export from there … but again, why enforce the work around just to achieve a basic clean image export?
The other thing we’re really missing—and the reason we’re still using Miro—is retained meta data. For context, a key use case for us is collecting and collaborating on AI-generated images and storyboards. Meta-data on images includes critical prompt info. When that’s striped out, it dramatically reduces the utility for us.
Tappy_David_J
May 6, 2025 9:15 AM UTC
+1 to this
If i ‘export selection’ it should just export the selection. The addition of adding a very large border seems strange, i can’t understand why you would add it?
At least have a check box to apply border or not in the export selection dialog
Please consider looking at this
Ana_Pirenjak
Sep 12, 2025 10:30 AM UTC
+1 for this to be an option when exporting selection.
Honestly, it doesn’t even look “aesthetically pleasing”. It looks more like a bug. There should at least be a checkbox to remove/apply this border as others mentioned.
Sam2026
Jan 19, 2026 5:05 PM UTC
This is very odd behavior. The default should be without a border and if people want a border than you can give them an option to do so. Why hasn’t this been resolved yet and when will it be resolved? It’s very annoying..
