Ed_Tramell
April 16, 2024
Dev mode Measure tool without full Design seat
  • April 16, 2024
  • 17 replies
  • 1672 views
Background: I am a developer, and I use Figma exclusively in Dev Mode via the web interface. I don’t have (nor do I want) any edit access to the designs I’m implementing. That’s for the designers.
When the Measure tool appeared (the ruler icon on the upper left toolbar), I latched onto it very quickly. It greatly improved my speed of accurately implementing a design. There are certainly other ways to measure things in Figma, but they are all transient. The best part of the new tool was that I could quickly measure many different things and have all the measurements persist so that I could then just refer to them during development. It was a simple yet well-conceived tool.
Then the Measure feature suddenly and completely disappeared on April 10! (Nooooo!!!) Other developers on my team can’t see it either, but the designers and anybody with edit access can still see it.
Has there been a change that means that edit access is required to enable Measure? I hope not, because if you asked my designers, they would tell you that they have no use for this feature. And I certainly do have a use for it in Dev Mode!
I’m surprised that I haven’t been able to find any news or documentation, nor even much discussion, about this issue. Can someone point me to some helpful info? Thanks!
Hey @Ed_Tramell, sorry to hear you’re having trouble accessing the measure tool!
Since you mentioned that you don’t have or need edit access, my first guess is that you previously had a full seat, which did give you access to the Measure tool.
If you’d like to check any recent permissions changes on the backend, please reach out to the support team directly via this form: https://help.figma.com/hc/en-us/requests/new
Ed_Tramell
April 17, 2024
Thank you @dvaliao – that at least confirms my suspicion that it’s a permissions issue. My team will have to reevaluate the value that we are (or aren’t) getting out of pure Dev Mode without Edit Access.
Can you explain the rationale, though? I noticed that Annotations also disappeared. This makes sense to me – only someone with edit access (e.g. a designer) would be adding annotations as information for a developer. But as I mentioned for Measure, I don’t understand why the designer would ever add measurements – that’s something the implementer would add as needed. So the permissions seem completely backwards for Measure. Does that make sense?
Thanks for the feedback, @Ed_Tramell!
We hear you. This is definitely something our Dev mode team has gotten before. To advocate on your behalf and guide the team on how we can improve, we’d love to learn more about your specific use case.
If we gave you Measurements, without a full seat:
  • Would you want those measurements to show for everyone, or just yourself?
  • Would you want those measurements to persist (through page refreshes or leaving and coming back)?
We’ll update your topic into a feature request and pass this feedback onto the Dev mode team!
Ed_Tramell
April 18, 2024
You’re welcome, @dvaliao – I’m glad the feedback was taken in the spirit it was intended!
For my specific use case on my specific team:
  • I would want those measurements to show just for me. I’m implementing a design and trying to be as pixel-faithful as possible, so I add measurements to convert the design into sort of a blueprint to follow. I’m probably the only person on the whole team who needs those measurements for this particular piece of a design. (For anyone else, it would probably just clutter up the design to see my personal measurements.)
  • I would definitely want the measurements to persist for the whole time I’m implementing this piece of the design. Mostly because I feel like I don’t have a lot of control over how/when Figma decides to refresh itself (I assume because of app updates or something?). I’d also expect the measurements to still be there if I navigated away and back. (If your developers are worried about the cost of persisting those measurements forever, then maybe there could be an expiration date or something before they get removed. Once I’m done implementing a page/dialog/whatever, I probably won’t ever need those specific measurements again and I could re-add certain ones if needed. But that’s a tricky thing to implement correctly without making some Figma user angry somewhere. 🙂)
Basically – I’d want Measurements to work pretty much exactly how it was working before it disappeared. (Based on what you said in your previous response, I’m still not sure why I had it for a while. But I did, and I used it while it was there. I can still see measurements I added to designs before I lost that ability.)
This is perfect, @Ed_Tramell!
We’ll pass this along to the team to discuss, and in the meantime, don’t forget to also Vote up top! ☝️
We use votes from the community to gauge the overall interest and impact implementing this change could make for all of our users. Thanks again!
Martin_Hardee
February 13, 2025
I agree it would be very useful to have the interactive Measure tool available for Dev Mode licenses. That way, Developers could measure a design themselves rather than having to go back to their designer to ask for it to be marked up!
Charlie Fishtank
I agree with everything ​@Ed_Tramell has said. I equally love using the measurement tool and I believe it to be more of a developer tool than a designer tool so having it available to those with Full Access in Dev Mode makes more sense to me than letting just designers use it.
Would love this feature back without needing Design Mode edit access please and thank you!
Steve13
The measurement tool is a feature the devs that I work with are constantly asking for and when we switched from zeplin to figma (dev mode) for our hand-off tool the developers were all excited about finally being able to have a way to measure things when they needed to. We are just now discovering that none of the devs have access to this since they have dev-mode only seats.
Martin_Hardee
April 22, 2025
I’ve been playing with the Measure and Annotation features that are newly in Design Mode and will say they are very nice to have at my fingertips now. Well done!
I agree with the posters who think the Measurements and Annotations need to be visible to view-only users also, since they’re frequently reviewing this type of work.
Römason
Also our developers are missing the measurement tool. Please re-enable it for the Dev Mode.
