Sean_Sands
Mar 16, 2021 9:00 PM UTC
Define default padding for Auto Layout (or set to 0)
    When you create an autolayout frame, it always defaults to 10px. Many design systems call for an 8px grid and in many cases, users don’t want ANY padding especially where edge-to-edge designs are concerned.
  2. Ask questions to bring the community into the conversation
    What are everyone’s thoughts about the following solutions?:
  • Default autolayout padding based on the big nudge amount in your settings
  • Allow for tokenization of padding/margin grids and offer up autolayout parameters based upon those tokens
  • Allow users to override the padding to 0px at the creation of the autolayout frame by using an alternative key command like ctrl+shift+a (command on mac)
ES_Design
Jun 26, 2025 3:57 AM UTC
+1 Default Auto layout padding & spacing = 0px
David142
Sep 2, 2025 3:51 AM UTC
OMG this is 4 years old?!
Whoever thought that 10 px would be the most common value users would want? 🤔
Nick_Man
Sep 26, 2025 8:55 PM UTC
Classic Figma - an entire 3 pages of discussion where the is basically a consensus among their users… and not action. It’s like they themselves don’t have a UX team sometimes...
Ben_Buckley
Nov 20, 2025 12:49 PM UTC
+1 for 0 padding on auto layout FFS
Matthijs_Rouw
Dec 10, 2025 9:24 AM UTC
I'd op for a configurable default value - if you want 0, you can choose that but I'd like to be able to select a default spacing token from our design system.
Naomi_Adkins
Feb 5, 2026 12:06 PM UTC
+1 (not that it appears to be helping!)
Adding autolayout should NOT change the size of an existing frame. How is that so difficult ☹️
There could at least be an option to add auto layout AND not change existing layout (like you’d get removing it). There’s an option to “Suggest Auto Layout” which COULD add a default value, but it shouldn’t with the normal “Shift + A” command.
Airwrecka
Feb 23, 2026 8:13 AM UTC
So annoying, pls fix this figma 😭
Alvino
May 18, 2026 9:14 PM UTC
Please figma fix this. We don’t want your arbitrary 10px margins
d_greg
May 19, 2026 6:05 PM UTC
This could live under the Nudge setting, for default values of some properties (gap, padding) which for me is also annoying. “Set default properties” doesn’t really save the properties for AutoLayout.
Serkan_Zararsiz
May 20, 2026 12:51 PM UTC
Yes, using Shift + A on a single item should default all spacing to 0px
