emreo
Jul 10, 2025 7:59 PM UTC
Corner Smoothing: Remember last setting
I truly enjoy using Figma. However, there’s a small but repetitive issue I keep encountering — and over time, it becomes tiring. Every time I create a new shape, I have to manually set the "Corner Smoothing" value to the same number again and again. In reality, this is a setting that is usually defined once at the start of a project and rarely changed afterward.
A simple suggestion:
Let the last-used value persist automatically.
Additionally, accessing this feature is unnecessarily hidden and distant in the UI, which slows down the workflow. That’s the second minor issue.
I've included my own approach to this below.
But if persistence is added, this visual suggestion could be considered a second improvement.
In short:
If something doesn’t need to be repeated but still is — there’s probably a design opportunity there.
As a bonus feature, having a "Apply to all corners" button would make it even better!
Thank you Figma!
