Meghan_Rose1
Jun 22, 2023 9:19 PM UTC
Copy/Move variable groups into other collections
I have been playing around with creating variables but realized I would rather have groups in separate collections, but cannot move them.
I would like to be able to duplicate an entire collection so I don’t have to manually re-create values and can remove what I don’t need from that collection OR simply be able to move groups into other collections.
[The title of this post was edited from “LAUNCHED: Copy/Move variable groups into other collections” to “Copy/Move variable groups into other collections” by a moderator on 17-Jan-2026.]
schoon
Nov 30, 2023 7:23 PM UTC
Awesome! Definitely going to check this out. Thank you!!
Thomas_Hallgren
Dec 6, 2023 6:56 PM UTC
Thanks for the tip. This plugin solved my problem.
Giancarlo_Gamberini
Dec 18, 2023 12:09 PM UTC
Hello Stephane,
I believe moving groups of variables across different collections should be a straightforward native Figma feature. For now, if your plugin allows for that, I will buy the license right away.
Unfortunately, I still don’t understand how to use your plugin to do that task. Can you please make a video to show just that?
Use Case:
  • I have a file with these variable Collections:
    • _Primitives
    • Measures
    • UI Colors
  • The Collection UI Colors consumes variables stored in the _Primitive Collection as aliases.
  • All variables are consumed by multiple components created in the same file.
  • In the Collection UI Colors there are two Groups:
    • General
    • Components
  • I want to move the Group Components to a new Collection (in the same file) without breaking any variable alias link. At the same time, I don’t want to lose variable assignments to the components in the file.
Thank you!
Matt_Wierzbicki
Jan 15, 2024 1:34 PM UTC
Hey everyone, I wrote an article on how I managed to move variables between collections. In the article, you can learn how to divide a single variable collection into separate collections. I hope it will help you!
Medium – 15 Jan 24
Jan 16, 2024 9:19 PM UTC
It would be very useful to be able to move a group of variables to another collection as I want them to have different mode names or no modes at all just for that group
Irfan_Dahir
Jan 17, 2024 8:35 AM UTC
Much needed feature.
Scott_Clark3
Jan 23, 2024 6:48 PM UTC
Man. Just move 36 color variables into a new collection. Seems like every time I find a need to do something simple that should have been thought of, I have to buy a new $20 plug-in. No thank you! I’ll just do it manually and complain about it.
Armin_Rouhanian
Jan 29, 2024 11:12 AM UTC
I just had to manually copy +50 variables with double modes, again. I couldn’t help myself & had to come here and complain again… WE NEED THIS FEATURE ASAP!
Armin The Riverman
Santiago_Sola_Morales
Jan 31, 2024 2:04 PM UTC
Awesome! I see that you have been exploring and experimenting with variables, but you have now discovered a more efficient way of organizing your data. That’s great news! Let’s work on finding a solution to help you duplicate entire collections and move groups into other collections seamlessly. With this new approach, you’ll save a lot of time and effort. Exciting times ahead!
Jan 31, 2024 2:06 PM UTC
Hey there! Thank you so much for sharing your thoughts, Ron_Frank! It’s great to hear that you’ve found the [Sheets to Variables] plugin to be helpful. I’m going to give it a try and see how it can make our work even smoother. It’s awesome that the author is planning to add an option for assigning tokens too - that’s going to be a game-changer! Your tip has brightened up my day, so thank you again for sharing!
