Andre_Correia
Feb 8, 2022 4:48 PM UTC
Copy comments when duplicating a page, duplicating a project, manually copy-pasting frames, etc
Hello,
Are there plans to keep comments within pages/frames when:
  • Duplicating a page
  • Copy-pasting all the elements within a page
  • Duplicating a document
I tried all three methods and the comments don’t get copied across, there’s also no way to select them to manually copy+paste them.
I see absolutely no reason for this not to be the default behavior when performing all of the above actions.
Are there plans to introduce this?
If so when do you plan to add it?
Thank you!
Amichai_Oron
Nov 12, 2025 12:51 PM UTC
WOW this features is so OVER DUE -  we need to be able to copy comments into a new file - why ?
Becuase clients want to move the project to thier team in the middle of work
Because we would like to duplicate a work without loosing the comments in the next sprint
Because we do period.
How: when you copy files drag to select press a modifier key like CMD+Shift+Ctrl+ v
what happens to the comments - they are added as new comments with new numbering
easy right - So just do it
Tomás Mariz
Jan 6, 2026 2:35 PM UTC
This is needed, please!
FilipZ
Jan 8, 2026 2:39 PM UTC
+1, this is very needed in professional business setting. Companies use freelancers for UX/UI and sometimes need to change the contractor, so they need to have the ability to duplicate the project with all the comments to other account.
Silu Manandhar
Feb 13, 2026 7:01 PM UTC
Yes, We really need this feature to be able to copy / move comments to another design file.
‘Comments’ are critical to our design process, team communication, and workflow.
Andre_Correia
Mar 11, 2026 2:24 PM UTC
Bumping this up. After all this time still can’t duplicate a document while keeping the comments that were originally there. Meanwhile all sorts of other redundant features are being launched.
RapidGator
Jun 10, 2026 8:35 PM UTC
Hey! I built a small Figma plugin called Spool that moves comment threads when you copy frames between pages or files.
It keeps every comment at its exact position with replies and authorship intact. After pasting, you can delete the original threads from the source or destination file directly from the plugin. You can also export a full migration report as CSV.
🔗 Plugin: https://www.figma.com/community/plugin/1644169490285295467
If you try it, I'd really appreciate your feedback — there's a feedback form built right into the plugin (Help  > Send feedback) or please directly add your comments in the community. Hearing what works and what doesn't helps a ton.
RapidGator
Jun 10, 2026 8:36 PM UTC
RapidGator
Jun 10, 2026 8:40 PM UTC
If you try it, I'd really appreciate your feedback — there's a feedback form built right into the plugin (Help > Send feedback) or directly add a comment on the community. Hearing what works and what doesn't helps a ton.
Yuri_Mikhin
Jun 25, 2026 10:15 AM UTC
Figma's had this request open for years — long enough there's now a tiny plugin turf war over it 😄 (hey Spool 👋).
I'm the dev behind Comments Mover — moves comments between any two files you can access, keeps the original authors, and you pick exactly which threads come along.
2 free transfers, and 🎉 code WELCOME = 15% off your first pack 🎉
https://www.figma.com/community/plugin/1563568797363678258
Solo dev, friendly inbox: urasergeevich@gmail.com — may the best comment-mover win 🙂
