Dan2
Mar 11, 2021 1:49 PM UTC
Control variant export naming (especially for icons)
When exporting variant names, the file name becomes a combination of all the variant properties.
There is no way to control the variant export name, which is especially difficult for developer hand-off.
In this example, I have a back icon variant group (Named “Back”) containing both an Apple and an Android variant of the back icon.
If I then go to export the Apple variant as an SVG,
The variant export name then defaults to “OS Type=Apple.svg”
Screen Shot 2021-03-11 at 8.35.40 AM
It would be even worse if I had multiple properties. For example, having two more properties could result in a variant name export as “OS Type=Apple, Direction=Left, Style=Line.svg”
This is a very poor naming convention, especially for icons. What I would like to have is the ability to control the name given to each variant export.
In the above example, I would like the Apple icon to export as the name “back.ios.svg” and the Android icon to export as “back.android.svg”. This way, our developers can export assets as needed directly from Figma without having to figure out what name to give each icon — further bringing together the designer/developer handoff.
Anyone else having this problem or have found a workaround?
Sep 3, 2024 11:21 AM UTC
I figured the best solution currently is probably to bulk rename afterwards. From the export, I got files such as “variant=user.png”. On PowerShell you can bulk rename the exported files like so:
cd [path to the folder]
ls * | Rename-Item -NewName {$_.name -replace “variant=”, “”}
which essentially removes the “variant=” from the file names. I hope someone finds this helpful.
Nick_Gertonson
Oct 15, 2024 10:27 PM UTC
This really saved the day for me and my engineers. Cheers!
Deanna_Liceaga
Oct 22, 2024 6:56 PM UTC
Hello, could this please be flagged and escalated in the roadmap? This is still an important issue.
RJ_Clarke
Oct 24, 2024 9:23 PM UTC
I personally love bulk exporting, and then digging through a series of folders and sub-folder to rip them all out, and rename everything by hand. Really cool system.
Michael_Mason
Nov 22, 2024 2:24 AM UTC
+1
Please Figma. I’m tired of policing both designers and developers from project to project when we could just maintain one Figma file for core elements.
Jacee
Mar 20, 2025 1:38 PM UTC
Bumping this issue because we’re dealing with it as well - Sketch does this better and that’s saying something.
Miguel ID
Mar 22, 2025 11:36 PM UTC
Hello! I had the same issue with the names of SVGs from Figma, so I created a free tool to quickly clean and rename SVG icons. You can try it out here: https://idgrafico.com/svg-tool.html. It’s a beta version, so any feedback would be greatly appreciated. Hope it helps!
Maya4
May 12, 2025 5:24 PM UTC
I have a workaround.
Let’s say you have three icons in a variant group called icon-circle.
  1. Change the property name for each variant to be named icon-circle. (or you can leave whatever property name you have assigned)
  1. Create instances of your components
  2. Open up the plug-in Set Instance Property as Name
  3. Click Rename (I couldn’t get multiple instances to rename at the same time)
  1. Export the assets from Figma
  2. Now do batch rename in your finder window by replacing the = (or the property name if you did not rename it within Figma) to whatever you prefer.
This is the only way I could figure out how to export a huge library of icons with various colours and sizes variations.
Hope this helps someone.
Thibaut_Dupre
Jul 9, 2025 3:55 PM UTC
I’m baffled Figma hasn’t addressed this yet, having a clean handoff when bulk exporting is really basic.
To add to the pile here’s my scenario, we have components with 4 variants: colored/not colored with background/without background
When exporting this is what I get
I’m exporting 410 images (hence the 57) … how am I supposed to know which is which?
I’d expect the NAME of the component in the export at least
is that too much to ask? Add a parameter to say [ ] Add name of the parent component when exporting
How would anyone differentiate the icons otherwise?
Rob McMackin
Oct 24, 2025 10:08 AM UTC
+1 here please fix, definitely a bug.
