Color Styles – Opacity & Multiple Fills
  • April 16, 2021
  • 20 replies
  • 10345 views
Andy1
If I apply a color style to an object as a fill (or stroke), I can’t apply any additional fills to that object. I also can’t change the opacity of that fill when it’s tied to a style.
Example: I have a button that is a frame with a blue background which is tied to a color style. I want to create a hover effect for that button by adding an additional 10% black fill on top of my blue color. Currently to accomplish this, I have to detach the blue from it’s color style, then add an additional fill black on top of it and reduce the 2nd fill’s opacity to 10%. See example screenshots below.
This not only breaks my blue color style, but if I have black as a style in my design system, I can’t use that color style either.
Has anyone found a workaround for this that I’m missing?
  • April 25, 2021
For the reference, I think this might be a different way to solve the same issue: Use styles in other styles
Eszter_Schuffert
Currently, when I have a color library and I need the exact color from it with X% transparency I have these choices:
  • Unlinking the color and adding the transparency → however, if the underlying color is updated, the color with transparency isn’t updated since it isn’t linked to the source color anymore
  • Changing the underlying color variable and adding transparency to it → I might use the color at different places and don’t want to add transparency everywhere
  • Creating a source color with transparency and some without → is possible, but adds additonal complexity, especially when you have many colors and might be hard to maintain
Bildschirmfoto 2021-05-10 um 11.26.19
Currently it looks like this (as seen in the screenshot). I would wish to have a transparency option next to the “-” icon.
The main issue is, that also developers use the Figma files as source of truth and they expect all colors be named. On the other hand, it isn’t practicable to have all transparency possibilities in the color library as it would get very complex very quickly.
Michael_Laugesen
Is there any news on this?
I find it odd that we are unable to add multiple fills when using styles
Deus_Ex_Pixel
There’s also the fact that you can’t toggle hide / show the fill anymore when a style is applied.
I don’t see why there would be a compelling reason to lose functionality when using a style as a fill or stroke.
Chris_Kerr
  • December 6, 2021
Really keen on this. I want to abstract state’s for fills & borders, which if we could apply multiple styles to fills, stroke and text colours, could be done without the need to declare each state for each type independently (e.g. I would have a Hover abstraction with is a tint of x% which I’d add above the style of each layer). Makes managing tokens much easier to have this abstraction
Vladimir_Pavlovic
Yeah, this is a HUGE problem when designing and using a Design System in Figma… You’re left with no choice but to unlink color style of object, to be able to change the opacity on Auto Layout or Frame button. That means update-ing color styles in the design system wont apply those changes to those unlinked elements
rahend
  • Active Member
  • December 21, 2021
Hi Figma, here I just wanna ask if there are any possibilities in the future development to have multiple color styles in the same object.
In my case, I wanna create an object with primary color and opacity blend mode to make a hover state object style such as button
Michael_Dillingham
Adding another vocal vote to add this functionality. The workaround right now is to have myriad color styles that look very similar which makes the color style palette kind of useless.
andrea-hg
  • Active Member
  • April 12, 2022
👆 👆 👆 👆 much need
Rudolf
  • October 28, 2022
We need the option to change the transparency to a fill style without breaking it first. Common!
Amr.Kamel
  • December 27, 2022
This is extremely needed to reduce the number of color styles when working with large design systems. Every time I want to add opacity to a color style, I have to go and create a new color style for that opacity value. which totally overwhelms the color palette 😦
Pablo17
  • May 22, 2023
need this +1
Jamey
  • May 24, 2023
Please, for the love of systems, can we adjust opacity on color styles. It’s probably a UI puzzle but this is a huge thorn in the side.
Joe_Robinson
Would love to see this! It seems like fairly core functionality for anyone working with color styles.
It reckon it would fit into the UI pretty easily but I guess it could well be a tricky update behind the scenes.
David_Praznik
+1 need this also
ROB002
  • August 15, 2023
How is this still not implemented?
please this needs to be implemented, it’s driving mad!
Shamari_Cooper
The closest solution to this is that I used an inner drop shadow effect with the settings of
colour: white or black (your choice)
x: 0
y: 0
blur: crank it til it fills up the btn
Then you can save this as an effect style and reuse it throughout the document. So I essentially treat tints and shades as an effect.
Lucy
  • August 1, 2024
I have a different workaround. Admittedly, I don’t know how smart this is in development, but I’ve heard no comments from any engineering team that I’ve worked with.
I add an overlay with
  • Position set to Absolute
  • Constraints set to Scale both ways
    then add my fill variable and adjust the layer opacity instead of worry about the fill opacity.
Jeroen9
  • July 9, 2025
4 years later and no update… I wish Figma had more competition so that they’d start making useful updates instead of all the crap they are launching in beta.
